Old 09-14-2013, 10:46 AM   #1
robert_63
robert_63's Avatar
O2 sensor codes
My 5.3 ls swap is now throwing o2 sensor codes, I didn't see the Code number at autozone where they read it, but the guy said Both sensors showing codes for the 02 heater. What are the chances that both sensors went out at same time? The engine and trans had 140,xxx miles on them and the sensors laid around in my toolbox almost a year before I got the truck running. I have about 300 miles on truck since swap and it just started showing the codes.
robert_63 is offline   Reply With Quote
Old 09-14-2013, 12:59 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: O2 sensor codes
What is your harness set up for? I've seen a couple guys put universal oldschool o2's on, and many of those don't have the heater circuit.
The Bosch's that many of us use, or the stock o2's should have the built in heater circuit. It would be weird to think it took 300 miles tho.
My o2's come close to the headers, you sure the wires didn't lay on something hot?
Get the DTC it will tell us a tad more.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-15-2013, 01:18 PM   #3
BigRed76
BigRed76's Avatar
Re: O2 sensor codes
If it took 300 miles to set those codes then it's probably safe to say your wiring harness was modified correctly, like Br3w City said make sure the O2 sensor wires didn't get melted. But I wouldn't be surprised if it just needs two new o2 sensors, they are a maintenance item.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
