Old 09-14-2013, 05:23 PM   #1
vinco
Transmission Acting Wrong...???
Well, I finally got my 63 to a point where I can try to start it today, and it just plain didn't act right. It's a 230 with a factory 4-speed. By the shifter, the transmission is clearly in neutral, but the truck still lurches when I hit the starter, as if it's in gear. However when I push the clutch, the engine will crank freely, with no apparent engagement of the transmission, like it should. So something's up with the tranny, but I have no clue what or how to go about fixing it. Is this common with the big 4-speed? Any clues or ideas? Thanks!
vinco is offline   Reply With Quote
Old 09-14-2013, 09:06 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Transmission Acting Wrong...???
Looks like we're kinda stumped on this one. It's just a thought, but have you pulled the shifter out and verified it to be operating the tranny internals. I'm no transmission guy but I do know the stick has a big tooth on the bottom which engages the sliders that change the gears. Push down hard on the spring loaded collar at the base of the stick and twist to release, then the shifter pulls straight out. I used to pull my shifter all the time for theft prevention and noticed I could change the gears without locking down the collar. A quick peak with a flashlight verified their positions as they I changed them.
AcampoDave is offline   Reply With Quote
Old 09-14-2013, 11:27 PM   #3
vinco
Yep, I'm stumped too for the moment. I'm now wondering if maybe I've found the reason the truck was taken out of service... Most times there's SOME reason why the truck was parked in a field or a back yard or wherever - maybe this is the reason for this one.
Old 09-15-2013, 01:54 AM   #4
'63GENIII
'63GENIII's Avatar
What kind of transmission is it? Does it have external linkage that needs adjusting?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-15-2013, 02:03 AM   #5
vinco
No, it's the big top-loading granny-low 4-speed. I'll pull the shifter tomorrow and look inside. Coincidentally, it's a 2WD long stepper. I also ended up with a 64 long stepper with a 3-speed, which actually currently runs and drives.
Old 09-15-2013, 02:09 AM   #6
cgreen
I had a granny low years back and I seem to remember that there are 2 shifters that will fit into the tranny but one is slightly different than the other. this difference can cause shifting issues and/or engagement problems. perhaps someone put the wrong shifter in.
cgreen is offline   Reply With Quote
Old 09-15-2013, 10:08 AM   #7
Jeff La
If I had to guess, your stuck in gear probably because of a worn shifter. should be able to pull the cover and see what gear your in and put it in neutral. Had this happen years ago in an old one ton.
Jeff La is offline   Reply With Quote
Old 09-15-2013, 10:18 AM   #8
'63GENIII
'63GENIII's Avatar
IIRC, the shifter can accidentally be installed in the wrong position. I had a Clark 5 speed like that. If the "shift gates" ( where the end of the shifter crops into) were not in the right position when I put the shifter back in, it would do some strange things like you describe. Easy fix. Pull the shifter out and check to make shut that they are aligned.
Chris
'63 k15 long step
Old 09-15-2013, 03:31 PM   #9
FetchMeAPepsi
FetchMeAPepsi's Avatar
It may seem simple, but check to make sure the cotter pin hasn't come loose where the shifter connects to the linkage. If that falls out you can move it anywhere you want and it won't make any difference because it's just rolling around free
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
