Old 07-07-2003, 09:10 PM   #1
flyin99
creator of kong
flyin99's Avatar
Unhappy TH700R4 T.V. cable adjustment help needed.......
I got a new TCI 700R4 and they sent a universal type TV cable, with the little set screw thing on the cable that you tighten where you need the cable to hold........how do you set these kind of cables, so the pressure is right........I am putting it on a Holley carb and I bought the bracket they said to buy, but these cables kinda rattle my brain a lil.......................Thanks Brad
flyin99 is offline   Reply With Quote
Old 07-07-2003, 11:35 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Your best bet is to get it to where it'll shift somewhat right, and head directly to a tranny shop that will use pressure guages to set it.
This is the only way to set it right.
If it does not get adjusted just right, you'll have a $2500 paper weight in about 2000 miles.
Old 07-07-2003, 11:39 PM   #3
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
yeah the pressure guage method is the only way... check out www.bowtieoverdrives.com as i think they've got a good instruction sheet on there but you NEED the pressure guage to know where things are set at.
And longhorn is right.. those 2500 dollar paper weights are a pain.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 07-08-2003, 08:50 AM   #4
flyin99
creator of kong
flyin99's Avatar
Thanks........will do.........
