Old 09-14-2013, 07:31 PM   #1
nvrdone
wipers, wipers, who's got good wipers
I'm at the point of adding electric wipers to my 3100. I want a kit that is 2 speed and self parking. I know there are kits out there but what would anyone recommend.
nvrdone is offline   Reply With Quote
Old 09-14-2013, 08:08 PM   #2
vht
Re: wipers, wipers, who's got good wipers
No experience with them but I seen Speedway has them. Whenever you get a set up that works good let us know, I'm going to have to get something for my 51. I need what you need, 2 spd, park etc.
vht is offline   Reply With Quote
Old 09-14-2013, 11:28 PM   #3
Kid
Kid's Avatar
i have Newport Engineering brand, fit fine & work good (2 speed & self parking)
Kid is offline   Reply With Quote
Old 09-15-2013, 04:52 AM   #4
S10Fan
Old Heap Driver
Mine came from Classic Parts and works perfectly.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 09-16-2013, 01:01 PM   #5
_Ogre
_Ogre's Avatar
ad or tf?
either way rainX is your friend
shop air compressor timer
Old 09-16-2013, 08:36 PM   #6
retired1
I used Rainx for a long time on another vehicle and when a vehicle in front of you throws up muddy water your in trouble. Newport Engineering on my 55
retired1 is offline   Reply With Quote
Old 09-16-2013, 11:34 PM   #7
nvrdone
1949 ad & rain x on the glass. I need wipers for those misty spring days in Seattle.
Old 09-19-2013, 06:05 AM   #8
47 Fasttoys
47 Fasttoys's Avatar
This is the unit from Classic parts, it is a direct bolt in deal with the switch pre wired. I think it is the same as Newport Engineering. I have used their unit on another build and it worked very good. The only issue on the AD truck is the upper cable for throttle control will no longer work due to space limitations. Hope this helps.
Rob
47 Fasttoys is offline   Reply With Quote
Old 09-19-2013, 01:04 PM   #9
nvrdone
I found out that Classic Parts sells Newport Engineering units. There is one that has a smaller bracket to clear the choke / throttle cable. Newport also sells an intermittent switch but Classic doesn't have it. The prices are the same so I'm putting the Newport unit on my C'mas wish list.
