Old 09-14-2013, 08:56 PM   #1
hotrod_991
hotrod_991's Avatar
Exclamation gas vs. diesel 700r4 help asap
I have a chance to get a solid 700r4 for my 77 c10.
The trans I am looking at getting came out of a early 80's c10 with a diesel engine in it. will this trans work with my sbc? if the convertor is diffrent i can get a new one also. more worried about bell housing bolts and the output shaft teeth.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 09-14-2013, 08:59 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: gas vs. diesel 700r4 help asap
They should be the same exept the converter. If you want to be 100% sure I can look at my 700r4 from my 6.2 but I don't know when I will be down there
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-14-2013, 09:08 PM   #3
hotrod_991
hotrod_991's Avatar
ok thank you insidious. like i said I can get a new stall convertor for a 700r4 sbc.
any idea if the diesel one is stronger due to the tq that the engine puts out?
and one last thing what do I need to change on my lwb truck to use the 700r4? drive shaft/trans mount? I know i will need a TV cable and bracket for carb
Old 09-14-2013, 10:13 PM   #4
INSIDIOUS '86
If you had a th350 long shaft it will swap in just move the crossmember, rearwards I believe
As for being stronger I'm not sure. They are calibrated for a lower rpm diesel so a shift reprogramming kit along with a torque converter should do it. A corvette servo shift kit should make it last pretty well with a stronger motor in front of it
And i can't comment in wether or not they had less clutches inside like the v6 versions as I'm not sure entirely but I would lean toward the internals being the same.
Old 09-15-2013, 01:21 PM   #5
hotrod_991
hotrod_991's Avatar
ok thanks
