09-15-2013, 09:32 AM | #1 |
GoatLube Experss
my 85 1/2 ton CCSB project
I bought an 85 crew cab car hauler a couple of year's ago, turn'd out that the bed was built weird (and short) so it didn't work out like I plan'd.
I ponder'd a few different idea's till I found a trailer made from and old 1/2 ton truck for a hundred buck's. I cut the front of the frame away from the half ton then cut the frame and bed away from the hauler.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
09-15-2013, 09:47 AM | #2 |
GoatLube Experss
Re: my 85 1/2 ton CCSB project
my half ton frame was along bed and I went with a short bed so I measure'd 14" back from the front bed mount bolt then 10 1/4" back from that mark. I cut the top off the half ton back to half way between the two new mark's . remove'd rge cab mount's and slid the half frame inbetween the frame rail's of the 1 ton frame. I left the front bed mount in the 1 ton frame and slip the half ton frame in till I had 10 1/4" between the hole's.
then I check's for level and set the bed floor on to double check my measurement's .
09-15-2013, 09:53 AM | #3 |
GoatLube Experss
next I swap'd the front suspensionand brake's to half ton add'n Belltech 3" drop spindle's.
09-15-2013, 09:55 AM | #4 |
GoatLube Experss
next was a flip kit and 25 gal. Suburban tank.
09-15-2013, 09:58 AM | #5 |
GoatLube Experss
the bed I'm use'n is actualy for my Dually, I will find a better bed later. I spray'd the bed white and add'd 20 wheel's.
09-15-2013, 03:36 PM | #6 |
It followed me home?
looks good! what are you doing for a fuel door?
damn I need to get working on my ccsb
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
09-15-2013, 03:44 PM | #7 |
GoatLube Experss
I was just out look'n at the fuel filler situation, not sure yet. I thought I would put it in the inner fender but that's not look'n good now that it's back togheter. kinda think'n I might raise the bed floor a few inch's, that would let go lower in the future and give a lot more room for the neck.
09-24-2013, 07:57 PM | #8 |
Great thread! I think I visited your Qalat location of Goat Lube Express. Had fast, friendly service and enjoyed 131 white macadamia nut cookies, thanks.
09-24-2013, 09:34 PM | #9 |
Slots go on anything!
After the fun I have had converting the rear of mine, I sure wish I had been smart enough to just graft in the rear of the 1/2 ton donor frame I had. Looks like yours turned out well.
1974 Jimmy- 5.3/4L80e/NP241 |
09-27-2013, 10:33 AM | #10 |
Me likey! I'm gonna wind up with one of these, I know it.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
09-27-2013, 10:46 AM | #11 |
Don't be a wuss, just do it!!!!
09-28-2013, 08:44 PM | #12 |
You, sir are a bad influence. Keep it up.
12-18-2013, 01:20 AM | #13 |
GoatLube Experss
I know this has been a while but I remember you stop'n by our Qalat location, you should come by the Clarksville location soon , bring the family and we'll find some white macadamia nut cookies/
