Old 09-15-2013, 02:00 PM   #1
WEBBY1
WEBBY1's Avatar
5 lug rear end swap
whats all involved? i found a 81 roller. plan on swapping front cross member. and swapping the rear to change to 5 lug.. its a 10 bolt rear end will that be ok? im new to all of this and plan to shorten the rear end to run a bigger tire.. it will be going into a 1965 burban.
WEBBY1 is offline   Reply With Quote
Old 09-15-2013, 03:32 PM   #2
shortbed70
shortbed70's Avatar
Re: 5 lug rear end swap
Spring perches on rear will need to be cut off and changed to coil arm perches and front I believe is just elongate a few holes...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-15-2013, 07:52 PM   #3
WEBBY1
WEBBY1's Avatar
I see a lot of ppl want 12 bolts. what's the difference between the two? What about the trailing arms
Old 09-16-2013, 12:41 AM   #4
Captainfab
60-66 Nut
If you change the front suspension, crossmember and all, you will have to drill 1 hole on each side, and elongate 1 hole on each side. As for the differential, I would recommend keeping your original 12 bolt and have that narrowed. The 8.5" 10 bolt is a decent differential, and will hold up to a good bit of abuse, but I see no reason to not use the 12 bolt that you already have. The main difference between the two is the size of the ring gear, 8.5" versus 8.875" for the 12 bolt, and the axle splines and possible the axle diameter. The 12 bolt will already have the trailing arm mounts and the panhard bar mount, so you won't have to have those transfered to the 10 bolt, which will save some $$. You're already going to have to purchase custom length axles, so you can order them with the 5x5 wheel stud pattern.
