09-15-2013, 04:54 PM | #1 |
Electrical Joy
1966 Chevy 283 3spd LWB HEI and corresponding alternator. Worked fine for ~6 years.
Earlier this summer I came into my garage to find that in the middle of the night, my truck crashed into my Camaro. Dang. Examination revealed that for some reason the truck starter engaged in the middle of the night driving the truck into my car (spun the tire on the truck after it hit my car), then smoked the starter wiring harness, melting the small wires in half and stopping the signal to the starter. From what I can tell the truck was only driven by the starter. Engine did not start during this event. Thankfully, the damage was only to the vehicles. No crushed kids, no burnt garage, didn’t happen in a parking lot, etc…. Had the starter rebuilt, new battery and re-made the wiring harness (firewall to starter portion). No blown fuses- before, during or after the accident. The harness going to the starter has; Wire that is always hot (Black) Wire that is hot when the key is in the ‘run’ position (Red- formerly cloth covered resistor wire) Wire that is hot when the key is in the ‘start’ position (Purple) Wire for oil or temp sending unit. (Green) I replaced the cloth covered resistor wire with standard stranded copper wire (Red). I verified power to these wires with a trouble light. When I turned the key to ‘Start’ position, the engine began turning over and attempted to start (hasn’t run since June) so I let the switch move to ‘Run’. The starter kept on going. Moved the key to ‘Off’ and it kept going. Jumped out and disconnected the battery. After re-checking everything, I tried again with same result. Suspecting the key switch, I pulled it from the dash and removed it. I jumpered the ignition key harness connector and the engine began turning over and when I removed the jumper, the starter remained engaged and turning over. Had to disconnect the battery. I tapped on the starter solenoid and the horn relay to see if that helped- no change. I am out of ideas and not sure what to try next- any ideas? Any input you guys might have is appreciated- S-D |
09-15-2013, 05:05 PM | #2 |
Re: Electrical Joy
O would suspect the harness between the firewall connector and the ignition switch is also melted at some point.
09-15-2013, 05:18 PM | #3 |
Re: Electrical Joy
Thanks- will check that next (though I'm not looking forward to it).
S-D |
09-15-2013, 08:14 PM | #4 |
Re: Electrical Joy
I would also suspect the solenoid.
Robert |
09-15-2013, 08:38 PM | #5 |
Re: Electrical Joy
09-16-2013, 07:11 AM | #6 |
Re: Electrical Joy
Thanks guys- I checked the wiring harness the best I could under the dash, bending it a bit back and forth from the passenger side firewall all the way back over to near the steering column. No change. If the starter checks out OK, I will have to do a more thorough check on the harness.
I am starting to wonder about the starter solenoid itself, even though it is new. Although, at the end of the day, I still haven't answered the original question about what made the starter engage in the middle of the night and drive the truck into my car. So maybe I need to get the under dash harness out of there and really look at it. That doesn't strike me as a good time. Thanks, SD |
09-16-2013, 07:42 AM | #7 |
Check The Champ, Demonstrator
Re: Electrical Joy
Is the cloth covered wire not a resistor wire? It's length is important as well. Sorry just read that you were aware of this fact. Are you running a stock coil?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
09-16-2013, 07:57 AM | #8 |
Re: Electrical Joy
You don't by chance have the Start and Run wires reversed at the starter, do you?
Altho with the HEI you shouldn't have the wire from the solenoid to the coil anymore. If it continues to act in this manner,with the ignition switch removed from the harness I am suspecting either wired incorrectly or the solenoid is defective internally. BYW the green wire at the firewall plug goes to the temp sender, should be a blue wire for the oil, unless you have OEM gauges, then it's hard lined directly. |
09-16-2013, 01:40 PM | #9 |
Re: Electrical Joy
since you have hei...take the "resistor" wire off of the solenoid(R terminal),try it and see what happens.....PS that wire is not a resistor wire,with org. coil it went to the coil side of the resistor OR resistor wire to give full voltage to coil for starting ...you may be getting voltage to the start wire somehow from that wire (the r terminal) if so it wont stop cranking
09-16-2013, 03:18 PM | #10 |
Re: Electrical Joy
TinCan- I had them switched once. When I turned the key to the 'run' position the starter engaged and wouldn't stop. So I switched them back- purple wire on 's' lug of the starter. The starter would engage when the key was moved to the 'start' position, but again the starter would still not turn off when the key moved to 'run' or 'off' positions.
JTRichard- I have removed the wire off the 'r' terminal of the starter- only the purple wire is attached to the 's' terminal. When I turn the key to the start position, the starter turns over and will not stop when the key is returned to the 'run' or 'off' positions. I plan to remove the starter and 2x check the solenoid and its contacts just to rule that out before going much further. Prior to removing the starter, I plan to short the hot lug and 's' lugs to engage the starter and see if the starter will stop turning when I remove the short. It almost seems as if the solenoid is sticking. Thanks, SD |
09-16-2013, 03:21 PM | #11 |
Re: Electrical Joy
Aero- HEI contains the stock coil as far as I know (no MSD stand-alone coil or anything) . Have not tampered with the distributor since I bought the truck.
Thx- SD |
09-16-2013, 06:32 PM | #12 |
Re: Electrical Joy
1 had a 1978 Cutlass that used to just start cranking over, while I was in the house. If you disconnected the battery and reconnected it, it would stop. the starter had a broken part that allowed it to make an electrical connection at random. Weird but true!! Took awhile to find it.
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
09-17-2013, 07:04 AM | #13 |
Re: Electrical Joy
All in for the 'bad starter solenoid out of the box' team.
Disconnected all wires to starter except the large battery cable and jumpered the 's' lug to the battery lug- engaged and wouldn't disengage. Time to pull the starter and see whats up in the solenoid. Thanks- SD |
09-17-2013, 07:32 AM | #14 | |
Re: Electrical Joy
Always remember when it comes to auto parts: " new means new, it does not mean good" |
09-25-2013, 07:33 AM | #15 |
Re: Electrical Joy
I removed the cap off the solenoid and found that when the 'washer' inside the solenoid would move, it would contact the wire coming out of the solenoid (wire to 's' terminal) and would cause the starter to keep cranking until I disconnected the battery.
Bent out of the way so it clears and truck finally starts and runs again. Now to re-hang the repaired fender. What an episode. Thanks for the insights- SD |
09-25-2013, 11:35 AM | #16 | |
Re: Electrical Joy
09-26-2013, 08:47 AM | #17 |
Re: Electrical Joy
Wow that's scary, so that washer caused a connection in the starter circuit over night?
I bet you'll keep the truck in neutral for now on in the garage won't you?
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
09-26-2013, 03:37 PM | #18 |
Re: Electrical Joy
As cheap as solenoids are, I would have bought another one!
