Old 09-15-2013, 08:54 PM   #1
69trk
69trk's Avatar
entropy radiator installed
Got er in.. just need to figure out how to wire it..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 09-16-2013, 10:48 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: entropy radiator installed
Mine came with instructions. What are you questions?
Hart_Rod is offline   Reply With Quote
Old 09-16-2013, 01:51 PM   #3
69trk
69trk's Avatar
Need to know if i take any of the wires to the holley ecu, plus the harness already has 2 relays and my ron francis fuse panel has built in relays for fans i think... when i get home ill check
1.58- 60'
11.37- 1/4 @115.81
Old 09-16-2013, 04:29 PM   #4
Hart_Rod
Hart_Rod's Avatar
I would use the relays that came with the radiator and trigger them with the Holley ECU.
Old 09-16-2013, 04:54 PM   #5
69trk
69trk's Avatar
Thats what im thinking.. will I have to use 2 of my outputs? Then I guess I wont have to use a switch with the ac?
1.58- 60'
11.37- 1/4 @115.81
Old 09-16-2013, 06:04 PM   #6
Hart_Rod
Hart_Rod's Avatar
Can you link me to the instructions for your EFI setup?
Old 09-17-2013, 09:46 AM   #7
69trk
69trk's Avatar
http://www.holley.com/data/TechServi...R10555rev3.pdf
i think this will work
1.58- 60'
11.37- 1/4 @115.81
Old 09-17-2013, 12:36 PM   #8
Hart_Rod
Hart_Rod's Avatar
I didn't see anything that looked like a fan signal. Do you have some programmable o/p's?
Old 09-17-2013, 01:43 PM   #9
69trk
69trk's Avatar
yea. 4 inputs and 4 outputs...
1.58- 60'
11.37- 1/4 @115.81
Old 09-17-2013, 02:26 PM   #10
Hart_Rod
Hart_Rod's Avatar
Cool. I would use those to trigger the HI and LO fans.
