T221 assembly issue
So I was bolting my TCase up tonight, and wasn't really paying attention. Apparently the new bearing for the input shaft is thicker than the old one, because it blew right through the cap on the back. Question 1 is, can this plate be welded? It looks as if it's made out of aluminum, so I'm thinking I can get it TIG welded. Question 2 is whether or not shims are still available somewhere.
Re: T221 assembly issue
Yikes that's blows! I bet it could be tig welded or maybe even brazed as long as it doesn't change the tolerances. Does that cap actually hold the bearing or just keep it in the case? That's weird that the bearing was larger than the original
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
It just keeps it in the case. I wouldn't have thought the new one would be thicker, which is why I didn't even think to watch for that. I put the original shims in. Guess that's what I get for assuming.
Posted via Mobile Device |
I've never been inside a 221 so forgive any stupid questions I may have. If you were to change the shims, would that throw off the gear lash? Or are you looking for a different (thicker) retainer gasket? Is it too late to return the bearing for the right one or too much to take it all apart?
Can you compare the new with the old? or did you toss it? wouldn't hurt to double check that thickness to rule out any possible assembly errors. Of course i have never been inside one so i'm not much help.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
My understanding - and you should confirm - is that the star shaped aluminum retainers hold the one piece ball bearings, like the rear input shaft, and only have gaskets behind them. The steel retainers, which use shims, hold the two piece tapered cone/cup bearings, like the idler shaft bearings, and the shims are used to set bearing preload. I believe that the ball bearings need to be driven onto theshaft/bore, and that if the retainer is used to drive them it can crack like yours did.
I have heard of guys fabricating retainers from pipe flanges. You would need to make sure there is a way for the oil from the holes on the case to get to the bearings. You can see how this works by looking at the inside of the bearing retainer. I would think that if you could weld yours up, and the result didn't leak oil, you would be fine. I don't think that the gear mesh is affected by that beareing because the shaft is fixed in the bore. There are pdf versions of the rebuild manual including exploded parts diagrams which can be very helpful. The best advice I can give is to keep the oil level up. The upper bearings can burn out if the oil level gets low. I once saw a "high level oil kit" somewhere. It consisted of a street elbow that screws in before the fill plug. Seems like a good idea to me. Also, from time to time, I have seen that part for sale on ebay. Good luck. |
#7 | |||
![]() Quote:
![]() Join Date: Jul 2012
I would think you could get that thing welded up. I'm pretty sure you can get custom shims made. Not sure what it would cost, but I'm almost certain it can be done. Just depends on how bad you want to keep the Rockwell unit.
Here are some links that might help on the shims possibly. http://www.aloma.com/custom.aspx http://www.metalshims.com/c-26-custom-shims.aspx
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
![]() Join Date: Aug 2008
I need to check but I didn't think you need to shim that rear cover for the input shaft. I thought it required a thick gasket.
But i could be wrong. I'll check the book. Posted via Mobile Device
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Post Whore
![]() Join Date: Feb 2000
Mike, I still have my old T221 that got damaged when I got low on gear oil and toasted some bearings. My retainer cap got torn up and I took this as a good opportunity to swap in an NP205. Looking at my old pictures, my T221 did have shims under that cap and I should have those still. If you need them, send me a PM.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I know this is an old thread, but for those of us still running the T221, I had my brother fab up a replacement solution...
I took some measurements of the old retainer, and how the bearing behind it apparently needs some play and butts up against the retainer (which is probably why they fail?) and then my brother made up a new one and welded it up. I later ground the oil passages into the retainer before rtv and install. I've been running this piece for roughly 5 years and it works great. here's some pics:
1964 ![]() 383 sbc stroker under vortec heads sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears rolling on 33x12x15 tires on 6 lug rims. ![]() |
Pretty creative fix for a fairly common problem with the 221.
For a lot of the 221s, a cracked bearing retainer is its death sentence. This kind of ingenuity is what keeps our trucks on the road long after many newer disposable vehicles are sent to be recycled. Good job on the fix there!
#13 |
When I bought my truck my transfer case was making a lot of noise. I found torque King had all the parts I need. Check them out.
