![]() Join Date: Apr 2013
71-71 drag link and front end parts
For Sale drag link for 1971-72 1/2 ton sold
Also I have several 1/2 ton frontend pieces for sale Front disk rotors (used) $20.00 + shipping Front spindles (used) $35.00 + shipping Front upper a-frames (used) $25.00 + shipping Front lower a-frames (used) $45.00 + shipping and any thing else you see in the pictures inquire about all is for sale crossmember (used) $35.00 + shipping
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy Last edited by tlcrz1972; 04-06-2014 at 02:12 PM. |
Re: 71-71 drag link and front end parts
What is shipping to 70769? interested in the drag link
I will check today.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
Shipping to you is $16.85
can you pm me your address and i will get a money order in the mail..
PM sent
Checking to see if you received payment and item shipped. Thanks Stephen
Posted via Mobile Device |
I haven't seen it yet.
Mailed money order on week today.. Have you received payment yet? If not I will have to file something with postal service to get my money back.. thanks. Stephen
Stephen,
I just checked and asked my brother as well, nothing has been received for me. I'll check it tomorrow, and I agree it should have made it here by now. Later Brian
TTT,
One more time, look and see if there is anything your interested in. I have a little more time left on my seller membership here, and then I'm downgrading to just being a member for a while. I'm about to get in the middle of building a new shop, and time will not be there for parts selling.
can you send more pics on just the cross member and a shipping price to 27583 thanks
#13 |
Just to make sure are you interested in the transmission crossmember, or the fronted crossmember?
#14 |
I'm converting my 69 from 6 lug drum to 5 lug disc. Will those rotors mount up to my front end and still work? If so my zip is 74764
#15 |
front end
#16 |
To do the swap you'll need the spindle knuckles, calipers, brake hoses, steel brake lines and the mounting brackets, lower a-frames and balljoints, and I'm pretty sure you'll need the upper ball joints and the tie rod ends as well (but suggest you by the U & L ball joints and tie rods and brake hoses new)
The brake line brackets are spot welded onto the crossmember so those will need to be cut off mine and you'll have to bolt or weld them back on your crossmember. Let me know if you want to go that way and I'll figure a price out.
#17 |
front end ?????????? a little more info please!!!!!
#18 |
I am looking for just the front cross member that the a arms bolt to
#19 |
OK that I can understand, how does $85.00 Plus shipping cost, and I won't know the price until I have it striped down and packaged.
#20 |
can you send me pics
#21 |
I finally got time to get some pictures, I had to get my tax stuff finished up to pay uncle sam.
Anyway here are a few pictures of the crossmember.
#22 |
Can you check how much for spindles shipped to 78729 if you still have them? Can you use a flate rate box for them?
#23 |
I'm sorry for the delay, for some reason I haven't been getting notifications of inquiries.
If your still interested let me know. Now to get a shipping cost I will have to take them off, which means time spent is shipping really going to break the deal?
#24 |
I found some locally last week. Thanks anyways
#25 |
