Old 09-16-2013, 01:59 PM   #1
Haggar
Ordered a 4" TC EZride lift, vendor sent me 6" lift rear springs.. should I use them?
Hi there,
Noob question:
I recently picked up a 72 Jimmy, and am in the process of some upgrades. I've heard a lot of good about the Tuff Country 4" EZ ride lifts, so I ordered one up, with the new rear springs, not blocks. So, everything came on friday, and I notice the rear springs are the 6" lift models (the 19670 springs). TC's catalog shows both 4 and 6" springs, so I assumed I would get the 4's with the 4" lift kit (19470 springs)
Now, I have read on here some people prefer this combo with 4" fronts and 6" rears.
Anyone have any thoughts? Would you run the 6" rears or see if I can get them swapped for the 4" springs?
Pertinent info for making the decision:
This will be riding on 33x12.5 tires, and is used for street driving, and sand dunes. The drivetrain will be lightened, mostly on the nose, with an all aluminum LS2/700R4/NP208, which should be ~150 lbs less than the 350/SM465/NP205 combo.
I have heard the EZ 4" springs ride better than the 6" springs. Shocks will be Bilstein 5100 series at all 4 corners.
I have many years of wrenching on 4x4s (mostly Jeeps, which our family has outgrown), but these are new to me.
Thanks!
Haggar is offline   Reply With Quote
Old 09-16-2013, 02:37 PM   #2
JJH Jimmy
JJH Jimmy's Avatar
Re: Ordered a 4" TC EZride lift, vendor sent me 6" lift rear springs.. should I use t
I got the same thing in the 4" EZ ride kit that i ordered from suspension connection. I called customer service and they told me that they are a 6" spring for 73-87 trucks but a 4" for 69-72 trucks.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 09-16-2013, 02:53 PM   #3
Haggar
Ahh, interesting. That is where I ordered them from as well.
Old 09-16-2013, 06:17 PM   #4
cleszkie
cleszkie's Avatar
That makes no sense to me. I understand that the rear springs are the same length for those two series of trucks, so if a spring lifts one vehicle 6 inches, it should lift both of them six inches. So if you ordered a 6 inch lift you would get a 6 inch front spring and the same 6 inch rear spring? Something is screwy.
cleszkie is offline   Reply With Quote
Old 09-16-2013, 06:50 PM   #5
drunkbus
New Member
drunkbus's Avatar
"so if a spring lifts one vehicle 6 inches, it should lift both of them six inches."
Not if the factory 69-72 rear springs have more arch to them than the factory 73-87 springs. If a 69-72 already sits 2" higher than a 73-87 then a 6" 73-87 spring will only lift a 69-72 4". If what they are stating is true, putting stock rear 73-87 springs on a 69-72 would lower the rear 2". Is that confusing enough?
drunkbus is offline   Reply With Quote
Old 09-16-2013, 07:16 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
I don't know for sure, but I think it has do do with the length of the rear shackle. On the 73-87 I think they are longer.
1985 Chevy K20
1994 GMC Yukon
Old 09-16-2013, 09:54 PM   #7
Haggar
Well, this assumes that the stock springs on both have the same arch.
In a simplistic view, if the stock height spring on a 1st gen had say 2" of arch, and the 2nd gen was flat, then if the new spring had 6" of arch, it'd add 4" to one and 6" to the other.
I'm just trying to make sure before I install them that its correct. Anxious to get them on, then the next phase begins: building the LS2, and then swapping it in.
Old 09-16-2013, 09:55 PM   #8
Haggar
When it was all installed, did it look correct?
Old 09-17-2013, 06:36 AM   #9
Chulisohombre
Chulisohombre's Avatar
The spring mount is also a lil different. Pretty sure when I got my 4 inch pro comp springs it was more like 6 inch as well. It sits pretty good though. Slight front stink bug but I added ord extended shackles up front so it sits èqual.
Chulisohombre is offline   Reply With Quote
Old 09-17-2013, 09:58 AM   #10
JJH Jimmy
JJH Jimmy's Avatar
I have the springs installed but my Jimmy is not all put together yet. I don't have the tailgate, bumper, seats, interior or top on it yet and the rear is 1" higher than the front measuring from the center of the hub to the wheel well. I think that it will probably be pretty close when complete.
1985 Chevy K20
1994 GMC Yukon
Old 09-17-2013, 10:10 AM   #11
Haggar
Thanks Your build thread has given me a few good ideas for my 6.0 swap as well
Old 09-17-2013, 10:13 AM   #12
turp mcspray
turp mcspray's Avatar
Blazer lifts come with the next size up, for the rear spring. This gets rid of the saggy rear stance. My 2 1/2" blazer lift came with 4" rear spring. My 6" blazer lift came with 8" rear spring. Install and go!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-17-2013, 10:51 AM   #13
Haggar
Sounds like its time to start spraying bolts. Thanks for the info guys!
Old 09-18-2013, 01:03 PM   #14
Burt4x4
Burt4x4's Avatar
Pre-made spring packs are made based on weight specs of the vehicle.
The Butt of a PickUp is much lighter than the Butt of a K5 or Jimmy.
Most all spring pack vendors do not make K5 or Jimmy specific spring packs because the pick ups are the same eye to eye specs and there just isn't a huge market for K5/Jimmys so they simply list the same packs used for the pickups.
It has everything to do with weight.
I put 4" fronts and 5.5" rears on mine.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
