Old 09-16-2013, 05:34 PM   #1
FLYNAVY30
Another motor mount/crossmember question....C20
Swapping an LS1 and 4L60E into my C20 Suburban. I bought the entire set up (engine, trans, flexplate, torque converter, shortened driveshaft) from a guy who abandoned a '69 Suburban swap project. My questions is, what mounts and crossmember to go with. I know lots of guys are running the dirty dingo mounts since they're adjustable, but with the shortened driveshaft, I should be able to keep everything in the factory location. I was thinking about using the CPP mounts and cross member. Any thoughts or input? Additionally, an issues using mounts that are advertised for C10s? As far as I know the motor mounts are the same between the C10 and C20.
Thanks for the help!
FLYNAVY30 is offline   Reply With Quote
Old 09-16-2013, 07:14 PM   #2
tinydb84
tinydb84's Avatar
Re: Another motor mount/crossmember question....C20
There are also the plate style mounts too. I don't think there is any difference between the two. I have a C20 and a C10 (different years) and they look similar.
David
Instagram: myfabguy
Old 09-16-2013, 07:28 PM   #3
FLYNAVY30
ok thats what I thought, thanks for the help!
Old 09-16-2013, 08:22 PM   #4
FLYNAVY30
Anyone running this set up?
http://www.brphotrods.com/installguides/1TKCK.pdf
Old 09-16-2013, 10:36 PM   #5
jorgensensc
jorgensensc's Avatar
I ran the dirty dingos on mine. You could always slide it to the stock location so the shortened driveshaft will work. I did use 73+ frame stands and 73+ dirty dingo motor mounts on my '72. Many just because the motor mounts are cheaper and sturdier than the 72 were.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-16-2013, 10:45 PM   #6
tinydb84
tinydb84's Avatar
Jorgensensc makes a good point. If you are going to be pushing bigger power I would switch them out for the 73+ style
David
Instagram: myfabguy
