Old 09-16-2013, 05:54 PM   #1
merlin3
rear shock relocators
i installed 5 inch drop coils and will be installing 1.5 lowering blocks on my 72 c10 do i need to install rear shock relocators? thanks
merlin3 is offline   Reply With Quote
Old 09-16-2013, 06:11 PM   #2
mgkgmc
mgkgmc's Avatar
Re: rear shock relocators
It will help you get more travel out of your rear shocks and the ride will be better.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 09-16-2013, 11:08 PM   #3
Slowgoin
Classic Parts sells rear relocator kits ($80/set w/new studs) and recommends them for any drop greater than 3". My truck is dropped 4" in the rear and I'm using stock locations without any problem. Not sure about anything more of a drop. Good luck,
Slowgoin is offline   Reply With Quote
Old 09-17-2013, 11:03 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I have 6"springs in the rear, I made my own relocators from the stock shock mounts. Swap from one side to the other and bend. The brace in the opposite direction.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
