Front Fender to Cab Seal
I purchased a fender seal kit for my 57 truck and I got 4 separate pieces for each side/fender.
The inner fender seal has a slit down the middle and I know where it goes. There is a thin piece with holes in it that gets sandwiched between the fender and inner fender. ![]() There is a smaller piece that I have no clue where it goes. ![]() And a long piece with no slit that they are calling the Front Fender to Cab Seal. No slit, no bolt holes, just a U channel. ![]() ![]() Anyone got any ideas where these two pieces go?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Front Fender to Cab Seal
the U shaped fender to cab piece gets glued to the fender right in front of the door
the rubber gets sandwiched in between the back of the fender and the cab hold it in the fender, you will see where it goes, better than i'm 'splaining it you can see the edge of it when the door is open it seals all the muddy water splash from your front wheels from getting in your step well ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
thanks Ogre,
I'll pull the fenders back off tomorrow and check it out.
