09-16-2013, 07:29 PM | #1 |
Bench seat hardware(cable)
Does' anybody know where to find the hardware for a bench seat for 71 gmc? Bought this truck and that's one of the things missing. Is there a cable or wire that goes from one side to the other? Can I use any old piece of wire? Need to pull one of you guys over with the same truck and look under there to see what I really need.
Thanks for any input Craig |
09-16-2013, 09:44 PM | #2 |
Re: Bench seat hardware(cable)
It's a solid rod from one side to the other from the factory.
You could use a cable if you want to but you will need to add an adjuster so you can get the length perfect. |
09-16-2013, 09:50 PM | #3 |
I never realized this was supposed to have a solid rod! Mine had a cable from since when I first got it and it worked just fine. Like Brian said though you will need to put a clamp on the cable though and I would think that it would work just fine.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
09-18-2013, 09:41 PM | #4 |
THanks for the info you guys
09-23-2013, 12:06 AM | #5 |
I am in need of all of the hardware that runs from the driver's side to the passenger side including the spring and clamp that sticks through the passenger side. The only thing I actually have is the arm on the driver's side. Does anyone sell this hardware?
09-23-2013, 12:08 AM | #6 |
I don't know about any companies but I've got nearly all of those parts kicking around that i pulled off of various seats. PM me if your interested. I've also got an extra set of seat mount brackets. I got my current seat from my neighbor and he's got 4-5 of these old trucks in his personal junk yard and he let me go through them to find my seat.
1970 GMC |
09-23-2013, 06:30 PM | #7 | |
