Old 09-16-2013, 07:43 PM   #1
Anti-Ricer
bag
I have been reading about airbags for my 65 chevy. I'm on a limited budget so I figure if I can either find a kit for just the front or if you guys can post some links or tell me what I need for just the front I'd piece together my own kit. I know bags,lines,compressor, tank but will any bag work or does it have to be a certain size cause I found firestone bags for 80 a piece and then I need this metal plate that makes it so I can mount the bags onto my stock control arms.as for lines,compressor and tank Idk yet.I'm asking now so I can a head start on this im going to be doing lots of searching, googling and reading up on it.for right now I'm cutting the coils but my ultimate goal is to get airbags under it not just for lowering it but for the handling and comfort.links would be greatly appreciated if you just so happen to know off the top of you're head a BUDGET front airbag kit for a 65 chevy truck please post it.
Anti-Ricer is offline   Reply With Quote
Old 09-17-2013, 07:29 AM   #2
tincan1966
tincan1966's Avatar
Re: bag
More often than not, when you try to put all the parts together individually, you'll spend more than waiting and buying a complete kit.
To do it right and make it last, you need:
either D2500 or 2600 bags
CORRECT mounting brackets and hardware
lines and fittings
compressor
air tank
control valves
switches and gauges
air line dryer/filter
shocks and relocater kits
adjustable panhard bar for the rear
possibly a one piece driveshaft -- may have to modify driveshaft loop
replace and /or upgrade ball joints and tie rods( in order to work with the extreme angles)
An improperly built air ride, or any suspension for that matter, is EXTREMELY dangerous. You should not just throw a set of bags on a 40+ year old suspension without making some changes/upgrades.
It gets tiring to hear, but do it once and do it right- mainly so you don't hurt yourself or anyone else with a parts failure.
tincan1966 is offline   Reply With Quote
Old 09-17-2013, 08:04 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: bag
I agree with Tincan, but I will interject this, you dont have to go all radical up front. you can do the front and and just dont air it out, then do the back when money allows. You can also do the bags with schrader valves until you can get the $ for the compressor and tank. I also caution you to do it right and take care of the worn parts first then do the bags. Call these guys, they will help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=595032
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-17-2013, 09:32 AM   #4
Anti-Ricer
Re: bag
Idk how I missed that site but 72 dollars per bag is a great a deal.I guess air bags are a lot like your home compressor when it comes to the air dryers and the Schrader valves is almost like a air shock.you fill it up and leave it that way then you lower/raise it by adding or removing air from the bag.I hope both bags hook up to one line so one isnt fuller than the other.
Old 09-17-2013, 10:28 AM   #5
T Smith
T Smith's Avatar
Re: bag
Use individual lines, you hook your bags together and it will roll side to side.
T Smith is offline   Reply With Quote
Old 09-17-2013, 10:46 AM   #6
racecougar
racecougar's Avatar
Re: bag
Agreed. Teeing them together will only exacerbate body roll in a corner.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-17-2013, 11:48 AM   #7
Clyde65
Clyde65's Avatar
Re: bag
I did the bags in the rear only, have a short ( 18") line to a schrader valve that is hose clamped ( kinda) under the rear fender. I usually dont have to fill either one up but if I would, they are very easily reached and filled. I would think you can do he same for the front, also I have drop shocks and i will get shock re-locators for the back when I have the cash.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-17-2013, 01:50 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: bag
Firestone bags are usually Sleeve bags, which is pretty much the lowest-end thing you can put on. They just aren't as good as a convoluted (sp?) bag from structure, ride, pressure holding ability, durability etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-17-2013, 04:03 PM   #9
Anti-Ricer
Re: bag
Im going to go with AirLift Dominator D2600 bags on the above link.I have no idea if they are lined or what that means lol but fill free to check them out and tell me what you think of them.you cant beat them as far as price goes but how they perform may be another story.any info you can tell me about bagging the front will be helpful.right now im going to go with the AirLift Dominator D2600 bags,
brackets to mount them on the stock control arms which are 79 dollars
http://www.azproperformance.com/63-8...-Brackets.html
Manual Schrader valve kit which is. 39 dollars
http://www.azproperformance.com/1-4-...Valve-Kit.html
If You see anything That I'm either missing or something I should get instead of what I have posted please fill free to let me know.
Old 09-17-2013, 04:51 PM   #10
T Smith
T Smith's Avatar
Re: bag
That will set you up fine for the front, and you can bag the rear for the price of the bags and schrader kit, just drill some holes and bolt them in.
Old 09-17-2013, 05:38 PM   #11
Anti-Ricer
Re: bag
Btw I have a solid driveshaft I guess the po done it when he put the 350 vortec in it.
Old 09-17-2013, 06:55 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: bag
I built my system piece by piece.. It was the cheapest option for me. I learned the hard way not to Tee them together.. I got some of my parts from WayLow2 if I spelled his name right.. I went with paddle valves and that has been perfect and have been using them for the last 3 years.. Virtually no leaks. In the next year or so, I would like to bag the front of my truck too.. The only thing I will need to add is two more bags and a new paddle switch/gauge setup for 4 bags. You can look at what I have done on my build page.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
