09-16-2013, 11:27 PM | #1 |
gear oil capacities
hi, i was wondering if anyone could tell me what the capacities for gear oil in a rockwood t221 t-case, muncie sm465/420 (not sure which one i have yet, probably 465) and the front and rear diff. i am looking to replace all the oils and need to know how much to buy. on a side note what is the best way to flush both the transmission and transfer case without wasting too much gear oil? any input helps! thanks everyone!
09-17-2013, 03:56 PM | #2 |
Re: gear oil capacities
If you are going to change everything, just buy a 5 gallon pail of 75/90 along with a pump. It will probably be cheaper in the long run and much easier to put in. The 465 alone will hold a gallon, front and rear diffs will be 2-3 quarts each along with the t-case. As far as flushing, not really a need, just drain and refill
09-17-2013, 03:59 PM | #3 |
I don't know, if you've seen how thick this oil is in my transfer case you might think differently. Besides I want out with as much old as I came and in with the new.
Posted via Mobile Device |
09-17-2013, 04:02 PM | #4 |
OK, so if that is the case, the only real way is to drain and refill, then drive it until it gets hot then drain and refill again. Repeat as necessary.
09-17-2013, 04:08 PM | #5 |
Yeah that's what I thought, but I was hoping not to use too much good oil to do it but if that is what I have to do then that's what I have to do.
