Old 09-17-2013, 11:30 AM   #1
kijocoz
power steering conversion 1970 C10 ??
can someone tell me what id need and need to do to convert my truck to power steering? its a 6cyl w/2 speed auto. thanks for any help!
kijocoz is offline   Reply With Quote
Old 09-22-2013, 07:36 PM   #2
bigmac73
bigmac73's Avatar
Re: power steering conversion 1970 C10 ??
buy the correct power steering steering box for that year, Napa sells them then get the hoses and pump and a mounting bracket, is not hard to do, look at summit for the pump and mounting bracket or a junk yard
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-22-2013, 07:56 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
When shopping for the pump,brackets and pulleys,make sure you get them all from the same vehicle.There are differences in the brackets and pulleys that can be a nightmare to match up.The box may be something you want to investigate further.If you use a 67-72 box,it will have approximately 4 1/2 turns lock to lock,which makes the steering feel (for lack of a better term)"mushy".The later box is 3 1/2 turns LtL. and has more "positive" feedback or roadfeel.Use a pitman arm for PS from the year of truck and it all just bolts up.Then use a string and adjust to the shortest setting.Wrap the string and measue it's length and get a belt.Fill the PS pump and start the truck with it on jackstands.Turn the wheel LtL several times,shutting off and refilling between times.Once all the bubbles disappear,you should have most of the air bled from the system.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-22-2013, 09:56 PM   #4
68 IRON
68 IRON's Avatar
Yep, not enough stress can be put on getting all the parts from the same vehicle...so many combos to match if you dont! This fact has been drilled into my head from this forum and Ive read about the headaches trying to match pulleys. PS pump, water pump, harmonic balancer and anything the belts wrap around GET!!! Oh ya....for the steering box grab the rag joint too...its a different size from the manual box. As for me....I have the stuff...just tryin to find the time to do it! Good luck and keep us posted!
68 IRON is offline   Reply With Quote
Old 09-23-2013, 07:49 AM   #5
NC67Chev
NC67Chev's Avatar
Panel and 68iron are giving you good advice regarding getting everything off of the same truck. That said, it will probably be much easier to find a set of brackets from a car, as I think there were a lot more 6 cyl cars produced with PS than trucks. I pulled my brackets from a Nova, found a correct 2 groove water pump pulley after digging through a pile of them for about 10 min, and picked up a gear from a local guy that had one laying around. You shouldn't have to worry about changing your harmonic balancer....at least I didn't....just make sure the spacing on the belt grooves on the harmonic balancer are the same as your truck on the vehicle you are pulling it from.
The bad thing is that most people now know the value of these setups, so they probably won't be cheap. They pop up on the board every once in a while. There are always several sets available on EBay.
It's not that hard to piece together, just be patient!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 02-07-2014, 01:28 PM   #6
sambudo
sambudo's Avatar
68 iron have you set your p/s up yet? If so hows it working?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 02-07-2014, 01:38 PM   #7
sambudo
sambudo's Avatar
I have my brackets, I have a feeling I will have a problem matching up as I dont have all pulleys from the same vehicle. I need to get the rag joint.
Old 02-07-2014, 04:10 PM   #8
NGN
NGN's Avatar
I'd suggest installing a sway bar up front. If not already , goes hand & hand with P S .
NGN is offline   Reply With Quote
Old 02-12-2014, 08:30 PM   #9
68 IRON
68 IRON's Avatar
Name:  I6 power steering 008.jpg
Name:  I6 power steering 010.jpg
Name:  I6 power steering 011.jpg
Name:  I6 power steering 013.jpg
1)pump pulleys
2)harmonic balancer and pulleys
3)the pump/alternator brackets
4)pump pulley
Old 02-12-2014, 08:35 PM   #10
68 IRON
68 IRON's Avatar
Name:  68 engine 69 grill 005.jpg
You can see the choke cable towards the back....and yes...it is a dirty engine!
Old 02-12-2014, 08:36 PM   #11
68 IRON
68 IRON's Avatar
All the PS parts came off a 79 Nova with non integrated exhaust head.
