Old 09-17-2013, 01:46 PM   #1
bigmac73
bigmac73's Avatar
sway bar parts info ??
i got a me a stock sway bar from the junk yard off of a 81 Chevy truck, I know i have seen the posts on here that show the required brackets and parts, can you guys help me out , mine is a stock 7/8 bar.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-17-2013, 02:44 PM   #2
mtnbikeman
Re: sway bar parts info ??
I pulled my bar from a 78 camper special and what I did was order a set of frame brackets from early classic enterprises (the lowered set for my truck) but they have stock height as well. For the bushings and straps you can get them from ECE also or head down to the parts store and order the bushings and straps for the year truck you pulled the sway bar off of. You will need 2 bushing and straps for the control arm mounting and 2 for the frame mounts. Add some grade 8 hardware and beer and your done.
mtnbikeman is offline   Reply With Quote
Old 09-17-2013, 03:19 PM   #3
bigmac73
bigmac73's Avatar
i was going to get the bushings and brackets from ECE but i noticed they have 1-1/16 and 1-1/8 inch, nothing for a 7/8 inch bar
Mike
Old 09-17-2013, 09:06 PM   #4
mtnbikeman
I purchased my bushings through summit racing. They have a good selection, and the bonus for me was there about a mile from my work.
