Old 07-08-2003, 04:31 AM   #1
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Question Electrical Question?
Ok, here's the story... While driving into work this morning my amp guage suddenly spikes from @14 all the way into the red to the 18. It did this once or twice real quick. Then about 5 minutes later, it spiked for about 10 seconds. It did this with my a/c on full, bright lights on, radio on, etc. Everything got brighter and my a/c fan started blowing harder!
What causes electrical spikes like this? Is my alternator going bad?
Paul
Low87on20s is offline   Reply With Quote
Old 07-08-2003, 11:51 AM   #2
Low87on20s
Live from Atlanta
Low87on20s's Avatar
TTT
anyone ever experience this?
Paul
Old 07-08-2003, 12:27 PM   #3
the baron
the baron's Avatar
I have ni idea if the voltage regulation happens inside the alternator or in a separate box.
What I remember from school ( a looong while ago...) is that a over voltage is very dangerous to the electric devices , you could kill your battery...
So , fix it ASAP
The Baron
____________________________________________________
1979 C10 long bed , 350ci Olds engine , stock
1977 Chevy Impala Sedan , straight six 250ci , "Ye Old Reliable"
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 07-08-2003, 12:30 PM   #4
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Thanks. I am concerned about the dangers of a spike because I still need to drive it 20 or so miles home from work. I guess if I see it spike, the only thing I can do is turn it off.
Paul
Old 07-08-2003, 12:33 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
I'm no electrical guru for sure, but if I were guessing, I'd say the internal voltage regulator may be going bad. I would pull the alternator and have it tested. But, unless it spikes while testing, it may not show up.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-08-2003, 03:33 PM   #6
rockman20
"The dude abides"
rockman20's Avatar
Definitely sounds like the regulator. Spikes are bad. Electronics do not like em. Hence why computers want surge protectors on them.
If you feel comfortable tearing an alt. apart, you can buy the regulator for it and replace it yourself. It's not that hard. Trickiest part is getting the bushings in their holder and sticking a pin in there to hold them.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 07-08-2003, 04:53 PM   #7
apstguy
LED King
apstguy's Avatar
Alternators produce AC but have converters to change to DC, so when they go bad evil things happen to your electrical system. Replace your alternator or regulator!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-09-2003, 09:00 AM   #8
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Well, I made it home yesterday and it spiked off and on all the way. The last two miles, it pegged at 18. I had to pull over and cut the truck off about 5 times in those last two miles. I pulled the alternator and luckily it was still under warranty. I had replaced it last July 22 when I replaced the battery and all the cables.
Everything is grand now. I appreciate everyone's input.
Paul
