what axle's will fit my 64 rear end
What year axle's will fit my 64 rearend i want to go 5 lug ??????
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: what axle's will fit my 64 rear end
If you are looking for a factory axle to just slide into your housing, they do not exist.
There are a few different manufacturers of the aftermarket conversion axles that will work to convert your '64 12 bolt to the 5x5 wheel stud pattern. However you will also have to chasnge your side spider gears from the 17 spline to the 30 spline to accomodate the new axles. The other option would be to have a machine shop turn down the hub register, and fill and re-drill your axles to the 5x5 wheel stud pattern. Before doing this, I would suggest closely inspecting the axle bearing surface to be sure they are worth putting money into.
#3 | |
Thank you that's what i needed to know .......
