09-18-2013, 07:50 AM | #1 |
Accessory drive question
What factory accessory drive set up fits best? I purchased my LS1 as a long block so Im going to have to do some junk yard searching so I wanted to verify whether the truck, Camaro/GTO, or Corvette accessory drive fits best for a 72 C20. Im also going to be running a Vintage AC system so Im going to need to purchase the appropriate adapter bracket for the compressor based on what accessory drive set up I run.
Thanks for the help. |
09-18-2013, 08:46 AM | #2 |
Re: Accessory drive question
It mainly depends on which intake you plan to use. The truck accessory drive systems are the most plentiful and easy to find. They also use a Saginaw power steering pump which is easily adaptable to run with the stock steering box. The biggest issue with them, though, is the idler pulley interferes with the intake ducting on Camaro/Vette intakes. This is easily remedied with an idler relocator. At this time, I can't remember who makes/sells them.
The F-body, Corvette, GTO, and CTS-V systems are harder to come by in junkyards, but can be found in the classifieds section at www.ls1tech.com. Keep in mind that each system uses different balancer pulleys, so if you get something from a junkyard, be sure to get everything from the front of the engine. The balancers require a special puller, so if you don't have one, getting a previously removed used, or even a new balancer may be easier. As for which one fits best, well, they all fit inside our trucks just fine. The only major modification will be adapting or making power steering lines and possible frame notching for the low mounted a/c setups. Dirty Dingo and Holley make some nice a/c compressor brackets that relocate them to the top, though.
09-18-2013, 10:32 AM | #3 |
Thanks for the info, I'm running a carb so the intake clearance isn't an issue. I'm also running vintage AC so Im going to need an adapter for the compressor regardless. Good info on the power steering pump.
Posted via Mobile Device |
09-18-2013, 10:38 AM | #4 |
Holley LS brackets....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-18-2013, 10:59 AM | #5 |
Location: Sunny, Florida, some might call it South Alabama
You just wanted to show off that big super charger Rob...lol
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
09-19-2013, 07:44 AM | #6 |
09-19-2013, 08:57 AM | #7 | |
http://www.holley.com/data/Products/...R10613rev7.pdf http://www.holley.com/types/LS%20Swa...y%20Drives.asp
09-19-2013, 10:22 AM | #8 |
Ahhhh....sweet! BTW, I've wasted a solid 2 hrs at work reading through your Suburban build thread...good stuff!
09-19-2013, 11:05 AM | #9 |
Hope you enjoyed it! Let me know if you have any other questions. Look in my 68 s/c thread, I have more pics of the brackets in there.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-19-2013 at 03:45 PM. |
09-19-2013, 01:32 PM | #10 |
So much for him getting anything done at work, now.
09-19-2013, 01:56 PM | #11 |
Work's over rated when you're not on the flight schedule
09-19-2013, 02:00 PM | #12 |
meowMEOWmeowMEOW
