Old 09-18-2013, 05:13 PM   #1
Nermal67
Active Member
WTB Rear inner bumper brackets for a 4x4 with leaf springs
Needing the rear bumper brackets that bolt up against the inside of the frame on a 4x4 truck with rear leaf springs. Thanks. Dave
Nermal67 is offline   Reply With Quote
Old 09-18-2013, 05:35 PM   #2
AHowe88
Re: WTB Rear inner bumper brackets for a 4x4 with leaf springs
These what you are looking for?
http://67-72chevytrucks.com/vboard/s...d.php?t=596898
AHowe88 is offline   Reply With Quote
Old 09-18-2013, 06:09 PM   #3
Nermal67
Active Member
No, those look like brackets for a 2x4 frame with coils. The brackets for leaf spring frames are a little longer and have a half moon shape cutout on the top. Thanks.
Old 10-31-2013, 09:05 PM   #4
JHawk
Are the trucks the same as the Blazers? I am starting to part out a 72 Jimmy. It has a rear bumper but I have not looked at the brackets. If you know if they will work and are still in need let me know. Here is a link to a pic of it.
http://dothan.craigslist.org/cto/4143586550.html
JHawk is offline   Reply With Quote
Old 11-01-2013, 11:38 AM   #5
Nermal67
Active Member
If your Jimmy has inner brackets they may be what I need, but I believe they changed the design in 1972 and the rear frame rails were extended doing away with the inner brackets. Let me know what you see. Thanks. Dave
Old 11-01-2013, 11:50 PM   #6
JHawk
You were right. Mine is different.
Old 11-03-2013, 12:29 AM   #7
Nermal67
Active Member
Thanks for checking.
