Old 09-18-2013, 06:55 PM   #1
ozbowhunter
window problems
I have just installed all the new door seals and window runs but I am having a problem and I cant seem to work it out
when I raise or lower the window it does not stay in any one of the runs so that when I raise it again it does not line up into the run properly is there a guide that should be in there what could I be missing ? any ideas anyone
ozbowhunter is offline   Reply With Quote
Old 09-18-2013, 11:55 PM   #2
Skunksmash
Skunksmash's Avatar
Re: window problems
It should just latch down, you might not have it latched down all the way. Can you get a pic of your problem put up here? When I put mine on, for example, I just laid it on there, lined up right, and hit it downwards with my hand. It will grab on there and shouldn't be able to come off without someone pulling it up. But that's for the lower window seal.
The rest of the rubber door seals, I put a little silicon where it wouldn't stay. Now it stays. If it keeps falling down, just glue it. You can always yank it down if you have to, and remove the glue. Better than dealing with it falling down or coming away all the time.
Skunksmash is offline   Reply With Quote
Old 09-19-2013, 09:26 AM   #3
walkerb
walkerb's Avatar
Re: window problems
Can you look at the other side as an example? Or did you do both at the same time?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-19-2013, 09:48 AM   #4
ozbowhunter
Re: window problems
I did both at the same time
the rubber seals and runs are fine they are staying well its the actual window that wont stay in position it fall out of the runs when it is put down then back up
is it supposed to stay in the back or front run?
Old 09-27-2013, 08:54 AM   #5
Skunksmash
Skunksmash's Avatar
Re: window problems
Sounds like you might have a bad, or bent window regulator. Might be time for a new one. I'd go with AC Delco even though they're more expensive.
Old 09-27-2013, 10:35 PM   #6
Oldriginal86
Re: window problems
The bottom of the "runs" or window track should be adjustable a small amount toward the glass. Possible the tracks were bent when removed. If they can't be adjusted any further in,raise the window and persuade (bend) them to tighten the window fit.
Oldriginal86 is offline   Reply With Quote
Old 09-28-2013, 11:42 AM   #7
ozbowhunter
Re: window problems
the windows where not taken out the passenger works fine and runs into the channel well but the drivers side seems to force more towards the outside and does not meet the channel will look into it more thanks for info any other possibilities?
