Old 09-18-2013, 07:11 PM   #1
TacBlade
What is this Plug? Pics inside!
Can anyone tell me what this is? I have no wires running to it? It is on the passenger side firewall?
TacBlade is offline   Reply With Quote
Old 09-18-2013, 07:29 PM   #2
mmiddle
mmiddle's Avatar
Re: What is this Plug? Pics inside!
Compressor relay
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-18-2013, 08:09 PM   #3
TacBlade
Compressor relay? So what was it used for on the original equipment? I have a new 383 installed now.
Old 09-18-2013, 08:14 PM   #4
71K20chevy
71K20chevy's Avatar
It was for the A/C compressor.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 09-18-2013, 08:18 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: What is this Plug? Pics inside!
Unless someone moved it to there it's not for the AC that I know of. The AC relay is inside on my 71 cab.
It maybe a relay for something at one time though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-18-2013, 08:43 PM   #6
TacBlade
If its for the AC Compressor, Should it be hooked up to it? I do have an updated Compressor that was put on, along with the new motor?
Old 09-18-2013, 08:51 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I believe that's the relay that keeps it from Dieseling.I can't remember what it's actually called.
Maybe anti-dieseling relay?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-18-2013, 09:10 PM   #8
Acorn
Not sure if its the same relay but I have one on my non a/c '70 It goes to a vac solenoid on the intake. The vac lines go to the vac advance on the distributor. I figured it was some kind of California emissions or something?
Acorn is offline   Reply With Quote
Old 09-18-2013, 11:34 PM   #9
71 super
71 super's Avatar
It is not relay for a/c it is a relay for tcs ( transmission controlled spark) it was connected to trans and vac advance and pulled timing out when truck sent into high gear. It was early emission device and had a vac solenoid that was electric and vac. Operated. On intake.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-19-2013, 01:47 AM   #10
DkOlive72
DkOlive72's Avatar
I'm with 72 super on this me. Pretty sure it is the TCS relay (having recently done a fair bit of research on the the TCS). You can search the forum for TCS and yo should find similar pictures of a relay in the same spot.
DkOlive72 is offline   Reply With Quote
Old 09-19-2013, 06:13 AM   #11
TacBlade
Thanks Guys!!! Its getting removed and thrown in the trash!!!
