Door issue - help needed - latch failed?
So last weekend, I got to Home Depot. When I tried to get out, the door wouldn't open. All of the actuating rods appear to be connected and working, but the door won't budge.
I am planning on removing the door panel - probably not easy with the door closed and the seat in. I am concerned that the issue is in the latch and I can't get the latch off without opening my door. The good old "Catch 22"! This issue is on a Blazer, but obviously it could just as easily be on a pickup. I figured that I would post here for a better chance of finding someone else that has run across it. Any help is appreciated. Posted via Mobile Device
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973. 70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch 72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior |
Re: Door issue - help needed - latch failed?
I've had this happen on my '67 Impala a few times. Has happened when opening the door from both inside and outside.
No idea what it is, but I've found that if I insert the key in the lock, lock it, then unlock it - with the key, not the lock knobs - then it'll open up. If you're inside the cab when it happens, you'll have to wind down the window and insert the key from there. You'll look like an idiot to passers-by, but it may be your only way out ![]() Sometimes you may have to lock/unlock 2 or 3 times, but it always fixed my problem. Just do it slowly and be sure you get a full "click" when doing it. Obviously it's something that moves when the door is shut - but I haven't bothered to investigate further. Hope that helps. Good luck! |
The Older Generation
If what Russ posted doesn't help check this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=415166 LockDoc
I appreciate the suggestion Russ. I hope all is well "down under". I'm thinking that a righthand drive conversion would be easier then what it is going to take to get thus door open!
![]() I went out to the garage this morning hoping that this would work, but no dice. ![]() It's not that the door has been an angel as it sometimes would refuse to latch too. In fact it did that 3 or 4 times before I got it to shut. When I got to my next stop, I found out that it decided to shut - for good! ![]() ![]() I'm afraid this will be a royal pain in the butt, so any suggestions are VERY welcome. Posted via Mobile Device
Push on the inside with both feet while someone holds the button in and lifts on the door. Taking the panel off gains no access. It's the latch stricker. THe part attached to the door frame. It's set wrong and the cover on the latch is jammed on to it.
Push, pull and lift. And wiggle! And Curse! And curse some more!! It'll come. |
Thanks LockDoc & geezer#99.
I finally got a chance to mess with the door some. I couldn't get it to budge by pushing on the onside and pulling on the outside. However after peering in the door crack, I could see the door latch was bound up on the latch striker. While trying to figure out what to do next, I spied a pile of gravel at the edge of the driveway. I thought I should try pulling the driver side front up on it and see if I can relieve the pressure on the latch. Well, it worked and the door popped open. Hopefully this is the wake up call I needed to take a run at re-alignment of the door. Posted via Mobile Device
#7 | |
Glad you got it open. Yup, I think I would adjust it while I had the chance... ![]() LockDoc
