Old 09-19-2013, 06:13 AM   #1
andrewilson
australian rhd build
so i decided id make a thread on my build.
Its a 1977 c20 i bought for $2000, came with an 010 350, mated to a 350 turbo and the rear end at one point had dual wheels. I'm about 5 months into the build so this thread is a bit behind, but better late than never. With the rules here of getting my liscene for the first time, i cannot drive 8 cylinders, turbo or supercharged, has to be 6 cylinder or less and a diesel turbo is allowed. a maximum of 210kw or about 280hp is also the rule here. i can get an exemption which will grant me usage of a v8 but are hard to obtain.
My plans where to get a 6bt and use that mainly for there torque, but decided to get a 4.3l v6.
1977 C20, Australian RHD, 4.3l v6 230hp
andrewilson is offline   Reply With Quote
Old 09-19-2013, 06:19 AM   #2
andrewilson
Re: australian rhd build
so i started off repairing the rust, it was pretty bad, the truck was pretty bare but had plenty of bondo. will upload photos when i work out how..
Old 09-19-2013, 06:25 AM   #3
andrewilson
here are photos when i first got the truck, should have kept it how it was but, i decided I was going to do a nearly full body off resto on a budget of not much and lots of time.
Old 09-19-2013, 06:27 AM   #4
Thomo5150
Hi Andrew, just use Photobucket to post pic's. you like this Forum, builds of different types and budgets as well as good advice.
Cheers
Thomo
Thomo5150 is offline   Reply With Quote
Old 09-19-2013, 06:29 AM   #5
andrewilson
thanks thomo5150, its good to see some more aussies on here !
Old 09-19-2013, 06:46 AM   #6
andrewilson
so here is the rust that was found, the front guards were shot from the rust so we have scraped them and are trying to find some more at the moment, later on i found more rust, sill, and corners but all is repaired now
Old 09-19-2013, 06:55 AM   #7
andrewilson
so the engine has had some oil leak in the last 10 years and it was so built up and thick even the pressure wash wouldn't take it off, so i had to scrap it all off. took the tray and guards down and put primer on and then took the tray off and took the chassis to bare metal with a wire wheel.
Old 09-19-2013, 06:59 AM   #8
andrewilson
so got the v6 for $500 it had the eldevbrock manifold on it, but i had previously found a holler street dominator for it, there isn't even information on the thing ! so its a rather rare piece. i put that manifold on there, i paint strippers the whole engine, painted it chevy orange and matte black on the sand blasted pulleys and pump. i think it turned out quite good
Old 09-19-2013, 09:31 AM   #9
walka
Great stuff
walka is offline   Reply With Quote
Old 09-19-2013, 04:34 PM   #10
Bainsy
Bainsy's Avatar
Nice truck pal, shame about the engine rules. Looks like your progressing well. Keep it up
1980 C10 SHORT BOX 454 THUNDER DOWN UNDER!!!
Bainsy is offline   Reply With Quote
Old 09-19-2013, 05:41 PM   #11
andrewilson
so got the firewall all down to bare metal, primerd, then repaired the rust that was just under the wiper motor, then painted 2pc gloss black, getting more paint today and will be painting the back of the chassis. will post some photos up when finished
Old 09-19-2013, 05:43 PM   #12
andrewilson
heres a better photo of primer
Old 09-19-2013, 05:46 PM   #13
l79m20
you sure got a lot done in one day
l79m20 is offline   Reply With Quote
Old 09-19-2013, 06:13 PM   #14
andrewilson
oh i wish it was one day, its been over about 5 months as i started this thread late, the cleaning of the tar and buildup took the longest
