Rim ID help needed
Does anyone know what year these are off if. I can't see a stamping on them and bought them for my 65. They look like they have beauty rim nubs on them which I don't recognize.
Posted via Mobile Device Posted via Mobile Device |
Re: Rim ID help needed
Do the faces of the rims have 3 or 4 bumps for the caps?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
There is 4 of them.
That would make it 71+ blazer, jimmy or 4wd rim...and some vans. I have never seen one w/beauty rim bump. I have 6 off a 73 4wd, but no beauty ring bumps. I have a buddy big in the 73-87 world....I can ask him what he knows on them.
Im guessing its a 15" rim? Edited...had to correct the date and add the van applications
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-20-2013 at 10:18 AM. |
What about the stampings on the outside of the rim? That'd help some. For example...These are May 1971 6 lug 4 bump here
They are 15's, I looked high and low and can't find a stamping anywhere.So they used these rims with the bump outs for the brake drum rivets until 72.
Im not 100% sure. What I was told by the 73-87 guys was the 4 bump face started in 73 and was used until around 91. And they were made for disc brakes...Ive only seen the 4 bump style like what I have, but I dont have trim ring bumps. I pulled the trim rings off my 63 6 bump rims and the trim rings fit the same, but my rings have the retainers on them, not the rims. Im not sure the make or application for the ones you have.
I am sure if they were on my 65 no one would know if they were correct or not.
I agree, I don't think that it really matters, as long as you like them. I went to the 4 bump 73 style rim because I wanted to retain my factory hubcaps and trim rings, and they clear disc brakes. The 4 bumps have a slightly longer opening on them, but its not really noticeable...and hey...I like them. Can you post a full size pic of them? Might help someone else in the future possible id them. Im interested to see it also. They might even clear disc brake calipers too.
This is what my 4 bumps look like....all painted up, just waiting to afford some wide whites to put on them.
One more note...any numbers would be stamped on the inside of the rim...you'd have to unmount the tires to see them.
The reason I went to these is because the rims I powder coated don't have the bumpouts for the rivets do they don't fit square. These ones do but they have the nubs on them that my factory suburban rim didn't have.
#13 |
Ones on my truck now.
#14 |
ahhhh, i see now. they are three bumps. i have a stack of them, ill go look through them tomorrow. your 4 bumps look like mine
#15 |
![]() Join Date: Aug 2010
#16 |
you could grind the heads off of the rivets also then your wheels would fit and look like the ORG. unless you pull the cap off
#17 |
Yeah, I thought about that but the powder coating didn't turn out as great as I wanted anyways so I am going to have another set done somewhere else.
#18 |
#19 |
![]() Join Date: Jan 2001
If they have 4 nubs they are disk brake used 71 up. If you check back side of will be square corner stamp to clear caliper. 65 will be 3 nub and back will be rounded out to edge of rim. But the 71 up wheels will fit fine. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
#20 |
![]() ![]() Join Date: Apr 2012
Its been my experience with NOS rims that when they have the "beauty Ring nubs" they are GMs over the counter rims. They did the same thing with car rims in the 60s and they are NOT originals, but are replacement parts. The markings will all be between the beads, not on the outside= Rim date and manufacturer. There was just 3 NOS 1960 rims on Ebay, 3 clip style and I darn near bought them till I saw the nubs on the outer edge of the rim. None of my original rims have those extra nubs. Still nice rims but not correct. Another way to identify these wheels is the valve stem hole size, larger is 63 and earlier on the 15 inch rims.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#21 |
between the beads is what i meant about outside of the rim, thanks for the proper term 60-66
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-20-2013 at 08:27 PM. |
#22 |
Thanks guys, we will see how long it takes at shows for the first person to notice they are over the counter rims. Any guesses, they were 10 a piece and are a matching set so I thought they would work better than the newer ones I have.
#23 |
Here is the stamp mark on the inside.
