09-19-2013, 03:33 PM | #1 |
Will not drive straight
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
09-19-2013, 03:45 PM | #2 |
Re: Will not drive straight
So I have just finished rebuilding the front end on the 72 and the steering has to much power under say 35 mph it's fine but if I go highway speed I have to keep correcting the steering and the steering wheel does not come back to center.
Parts replace inner/outer tie rods, upper/lower ball joints, upper/ lower control arm shafts,shocks, pitman, idler arm, steering box,rag joint, adjustment sleeves, and the pump is an original 67-72 power steering pump. After that I had it alined (driver side is left colum) Camber .1 .7 Caster. 1.5. 1.2 Toe .20. .21 Front Cross camber -0.6 Cross caster .3 The tires I have on are 205/65?/15 (I needed tires and they where free)the tires where balanced right before front end work. All I want is to have less power assit (less twitchy on the highway) Posted via Mobile Device
09-19-2013, 03:57 PM | #3 |
What is the date code on the tires? How much tread (in 32s) do the tires have, on each end and in the middle?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-19-2013, 04:20 PM | #4 |
The date code is 2110 so the 21st week in 2010. And as far as depth I was getting 6/32-7/32 on the outside and 8-9/32 on the inside the backs are at 8-9/32 too. The story on the tires my firends dad bought them for his ford tarus and about a year ago it blew a freeze plug, I got the tires back in June and ran on them with the bad front end until now
09-19-2013, 04:45 PM | #5 |
did you have it aligned? Theres a lot of talk of shadetree alignments on this site and for some that may work but the $140 I spent at the tire shop was well worth it to me.
09-19-2013, 04:48 PM | #6 |
sounds like your caster and/or camber are way out of adjustment
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
09-19-2013, 04:50 PM | #7 |
Yes I had it aligned ,the place I went charged me 70bucks ,I posted the after ailment results
09-19-2013, 05:04 PM | #8 |
Cluster King
A tire with good tread and balanced does not necessarily make it a good tire. What are the rear tires like, the same as the front? I would rotate them and see if your condition changes. You should expect a little (very little) pull from road crown but not like you describe.
I would say have them recheck the alignment but not until you are sure you have good tires. Did the alignment tech test drive the truck when he finished or just park it?
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
09-19-2013, 05:13 PM | #9 |
I should have stated this better my steering is so powerful it only needs a finger to turn the wheel
09-19-2013, 05:33 PM | #10 |
If the camber is .1 on the driver and .7 on the passenger and caster is 1.5 on the drivers and 1.2 on the passenger this could contribute to the problem. Camber will always pull to the more positive number and caster will always go to the smaller number. When I align a vehicle I try and get camber even and have a .5 split to the driver side to compensate for the road crown.
If your power steering is too touchy you might try a different pressure valve in the back of the pump.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
09-19-2013, 05:34 PM | #11 |
The more I look into it I think it might be the pressure valve in the pump and I need a weaker spring. Any idea where I would buy one
09-19-2013, 06:02 PM | #12 | |
09-19-2013, 06:52 PM | #13 |
What is the actual specification for caster?
1.5 degrees doesn't sound like much caster to me. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-19-2013, 08:12 PM | #14 |
So I have been looking more into caster and from what people on here say 2-3 is where a power steering truck should be. I will go back to the shop and see if they will reset the caster so the steering wheel will come back to center. I also found shims for the pressure valve on the pump so I hope that makes the steering more heavy. Thanks for all the hel
09-19-2013, 10:07 PM | #15 |
What was the pump from. You did mention it was the correct era, but was it correct for a truck. Used to work at the plant where those things are (well, were) made. They were different between a truck and a car.
09-19-2013, 10:10 PM | #16 |
Yes got it at Carlisle truck show and the guy said he pulled it from a c10
09-20-2013, 10:32 AM | #17 |
do you have a sway bar? that will help a bunch as far as tracking
09-20-2013, 12:25 PM | #18 | |
K
09-20-2013, 12:51 PM | #19 |
Just for reference, here my alignment specs. I have a few thousand miles on it, tracks great, wheel returns to center, no twitching, even tread wear.
Camber -0.1 0.1 Caster 2.6 2.6 Toe .20 .19 Front Cross camber -0.2 Cross caster 0.1
09-20-2013, 12:53 PM | #20 |
not true without a sway bar the trucks sway back and forth goin down the road//that is how they get thier name SWAY BAR
09-20-2013, 03:21 PM | #21 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-20-2013 at 03:36 PM. |
09-20-2013, 03:25 PM | #22 |
My thoughts- needs more caster- not too much, though. Then it won't steer well at all!
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
09-20-2013, 04:17 PM | #23 | |
go drive a vehicle without a sway bar and see fer yourself
09-20-2013, 08:00 PM | #24 |
Yup no sway bar . The more I think about it its caster, since the low caster I am over correcting which is the problem. I am still getting used to powersteering in a truck that for a year I drove with a 1/4 turn of slop. the schocks are brand new
09-20-2013, 08:45 PM | #25 |
Please read my profile and introduction thread.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-20-2013 at 08:56 PM. |
