Did power steering equipped trucks get a different inner fender?
I ask this because when my dad put power steering on my truck he used a power steering sector from a 1973 and he ended up cutting part of the driver's side inner fender away to make room for it. Sine I want to use my 1967 inner fenders now on my truck, I just wondered if they'd fit.
Will inner fenders from a manual steering truck fit a power steering truck? |
![]() Join Date: Mar 2012
Re: Did power steering equipped trucks get a different inner fender?
i dont think so, the gear box is under the inner fender, mine has PS , there is a pattern for the steering rod to go through, but all hoses are underneath the fender
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Not to high jack but could someone post a pic of the inner fender on factory P/S trucks? Mine was also converted to P/S and it looks like trimming may be required. This could be helpful for everyone wanting power steering.
Posted via Mobile Device |
#4 | |
I have neatly cut away the top section over the Gear Box. Way easier to get at and it does not look trashy. But it would be noticed by a 67-72 owner.
#6 | |
We all notice bad work but most of us are really forgiving when it comes to changes that are well done! ![]() |
![]() Join Date: Mar 2000
Bad radiator mounting pads will cause the front sheetmetal to sit to low and allow the inner fender to hit the PS gearbox. If your cab mounts are bad also it can make it slightly worse.
Paul @ GMCPauls |
Ah well thanks guys! I am in the process of replacing my radiator core support to frame bushings so that should help there.
Fitz, Where did you get your flex hoses coming off your power steering gearbox? |
I made them using Aeroquip FBC400 high pressure (3000 psi) hose and Aeroquip high pressure fittings on the pressure side and the same hose with ordinary screw clamps on the LP side. When you cut that hose you need to wrap it really tight with tape over the cut and use either a die grinder with a cutoff wheel or the ends will fray.
Active Member
![]() Join Date: Jul 2007
Inner fenders/wheel wells were the same but the engineers designed the original hydraulic lines for power steering to go under the wheel wells. Lots of carefully designed bends on them.
Most trucks that have been converted and even some that originally had p.s. have had the hydraulic lines replaced -usually with later year ones. I'd be surprised if someone is still using the originals.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Could somebody post a pic of a factory equipped power steering truck where the P/S gearbox and lines and inner fender all meet? I want to see if it looks different from my setup on my '68. Thanks.
![]() Join Date: May 2010
Does this help?
#13 |
Yes, thanks. Now I can compare it to what I have. At the moment, my inner fender is removed so it will be a while before I can compare. Does anyone know what the difference would be? The fender cut differently to allow for the gearbox/lines? or is it bent differently in that area? What should I be looking for?
#14 | |
#15 |
Thanks. I will take a look when I get home.
#16 |
And... another shot from under the inner fender.
#17 |
That one is very helpful, thanks!
#18 |
no,they have a notch already cut out for the power steering box.
#19 |
When I changed my manual to power it hit the inner fender bad. Come to find out there were no bushings at all under the core support. That explained the bang when I hit bumps. Inners are getting painted right now and bushings are in place so I guess things will go alright now? Although they are repops... Probably fight them anyway!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#20 |
Get all the fasteners started before tightening any of the down, then tighten each one a little at a time. That includes the drivers support bar.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#21 |
I cut mine like this and edged it with a piece of fuel line
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10 |
