Old 07-08-2003, 02:16 PM   #1
1969 4x4
Clear Coat question
i am wondering if u can clear coat over a single stage enamel paint?? or what the best way to get a good shine from an enamel paint would be???
1969 4x4 is offline   Reply With Quote
Old 07-08-2003, 02:52 PM   #2
Jwill41
Jwill41's Avatar
We painted mine with Dupont Centari then wet sanded it and applied second coat of the same. Then wet sanded that and applied clearcoat. I think the Centari is a single stage paint. I don't know much about paint but had help from my brother who only knows a little more than I do. LOL
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-08-2003, 04:38 PM   #3
raggedjim
raggedjim's Avatar
Just read about this the other day. You can clear coat a single stage but the clear coat should be thinner than on a two stage. 2 stage gets 1 mil base and 2 mil clear and a clear coated single gets 2 mil color and 1 mil clear. I'm no painter but I've been studying up on it for the future.
Thanks, Roger
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 07-08-2003, 05:54 PM   #4
70c10
67-72 Addict!
70c10's Avatar
They make clears that are formulated for enamel. Never used one though.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-08-2003, 10:06 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
DO IT RIGHT!
Go to the paint supply store. Get the information product sheets for the brand & type paint you are using. It will tell you exactly how to do it, what to use, problems, thinners, time frames and everything required. Don't mix types of paint or guess how to do it...If you don't do it right, there can be some real BAD results. The manufacturers have spend a lot of $$$ figuring out the best way to do this and their info is usually free. Your paint supply store should be your very good friend, if you are going to "do it yourself".
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
