Old 07-08-2003, 02:27 PM   #1
wxman1
Trim
I have found a donor truck with a good set of trim. Can't see paying $600
for new woodgrain type trim. Anyway...wondering what kind of tool I should
use for removing it from the donor truck? Anybody have any ideas on this?
Thanks!
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 07-08-2003, 09:07 PM   #2
JimKshortstep4x4
Smile
Starting on the lower trim, front to back:
Remove bumper-3/4" socket/box end wrenches,
Phillips screw driver and 3/8" socket is needed for front lower
piece
Rear front fender lower, 3/8" socket, 1/2" socket, and 9/16"
socket, (need to remove 5-6 bolts holding fender liner and
pull fender away from body to get at nuts, (2)
Lower door chrome, two 3/8" nuts, one at each end, fender
in the way of the front one, release spring on clip and rotate
clip with bent knife, center clips are glue on and can be
removed with a putty knife.
Lower cab, remove gas tank using 1/2" socket and ratchet,
(2) 3/8" nuts hold trim on.
Lower bed, front, (4) 3/8" nuts hold trim on, posibility of
glue on clips in the middle.
Lower bed, rear (3) 3/8" nuts hold trim on possibly two glue on
clips. Two phillips screws at rear.
Upper chrome front fender, (7) 3/8" screws hold the chrome on.
I usually pull fenders for these fasteners.
Upper door chrome, phillips screw in front, 3/8" nut in rear,
could be push in clips or glue on clips in the middle, if push in
clips, release clips and turn.
Upper cab chrome, (2) 3/8" nuts can be gotten to on right
side, left side, tank has to be out.
Upper bed chrome, the end clips are push in, release and turn,
middle clips can be either push in or glue on.
Good luck!
Jim
Old 07-09-2003, 03:20 AM   #3
Jemost 72
Southern Bowties
Jemost 72's Avatar
Jim, that belongs on the FAQ page! I got all mine removed this past weekend. The only part I can add is the upper trim on drivers side cab- I have a black air vent below the door latch that I removed to gain access to both nuts on the trim, didnt have to remove tank! Good luck and take your time
1972 Cheyenne 350/350
Jemost 72 is offline   Reply With Quote
Old 07-09-2003, 04:13 AM   #4
krue
Designated A-hole!
krue's Avatar
I copied Jim's post to FAQ, hope nobody minds!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-09-2003, 06:16 AM   #5
JimKshortstep4x4
Smile
Jemost 72,
That is a good idea on the plastic vent removal. I don't believe all years have it, but that will work!
Krue,
Thanks for posting the information on the FAQ.
Jim
Old 07-09-2003, 07:02 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
71/72 are the only ones with that vent in the door jamb.
