Old 09-20-2013, 02:08 PM   #1
deestrong71
deestrong71's Avatar
572 Install Questions
I have searched quite a bit and cant come up with the answers. So I pose my questions to the Forum Guru's:
I am installing a 572 BBC in my '71. I am having a hard time finding a set of headers for it,
I am needing at least 2" primary's that will bolt up to a Exhaust port that is D Shaped, all while fitting in my truck.
I do have Power Steering, A/C and a TCI 400 Super Street fighter Auto Tranny.
I do have a price quote submitted to Kooks for custom headers, but I am hoping there is something that meets my specs out there.
Hope, Faith and Strength
**Deestrong**
deestrong71 is offline   Reply With Quote
Old 09-20-2013, 02:36 PM   #2
Fitz
Re: 572 Install Questions
Call Sanderson Headers. They have a set of Gen 6 big block headers that Stacey David had made just for the 572 installed in a 67 Chevy Pickup for the Trucks TV show when he was host. They fit perfectly in my 67 stepside.
If you want to know what that monster motor will sound like when you are done go here:
http://s851.photobucket.com/user/BWF...out-1.mp4.html
Fitz is offline   Reply With Quote
Old 09-20-2013, 03:51 PM   #3
marvgarr68
marvgarr68's Avatar
All I know is that is awesome love the look. I always wanted to do a 572 swap but out of my budget looks great.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 09-21-2013, 12:45 AM   #4
67ctener
67ctener's Avatar
I used Sanderson bb8s on my 402 and have nothing but good things to say about them
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 09-21-2013, 01:47 AM   #5
deestrong71
That looks awesome, I just ordered the Sanderson BB8 for my 572 ! Whoop Whoop !
**Deestrong**
Old 09-21-2013, 03:55 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
Are you using big block stands?
WIDESIDE72 is offline   Reply With Quote
Old 09-21-2013, 04:41 PM   #7
deestrong71
havent used anything yet, My Motor hasnt shipped yet.
**Deestrong**
Old 09-21-2013, 05:03 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
In order to get the most clearance possible, you need to use big block stands and mounts. You have three choices for them.
1. 68-71 non captured type towers/ mounts. The replacement "biscuits" for these are sort of expensive. Some folks have modified small block biscuits.
2. 72 only towers that use a modern captured mount. These are a pittle more expensive initially since they are a one tear only part, but the replacement mounts are cheaper.
3. 73+ frame brackets. These visually look different but are usually cheaper all around. You will have to drill a few holes with these.
Old 09-21-2013, 05:49 PM   #9
ItsRandy
ItsRandy's Avatar
I have Hookers on mine, P/N 2841. They have 2" primaries with a 3.5" collector. I got mine through Summit. Ceramic coated I think they were $769.
They fit pretty good but not without some issues that were easy to fix/fit. The head bolts hit on the flanges, nothing an angle grinder couldn't fix and the driver's side lower control arm "kissed" one of the primary tubes. Again, an angle grinder fixed this also. They hang a little low but I have only "touched" them on a driveway (high center) a couple of times.
ItsRandy is offline   Reply With Quote
Old 09-21-2013, 06:02 PM   #10
ItsRandy
ItsRandy's Avatar
Another picture.
Old 09-22-2013, 01:08 AM   #11
deestrong71
Originally Posted by ItsRandy View Post
Another picture.
Your Setup Looks Great !
**Deestrong**
Old 09-22-2013, 01:09 AM   #12
deestrong71
I have a 454 installed in it now. I dont know what Motor Mounts it has as I didn't do the Install. but I got 2" room on each side of the header.
**Deestrong**
Old 09-22-2013, 04:59 PM   #13
skorpioskorpio
Randy, Is that a Ron Davis Radiator?
skorpioskorpio is offline   Reply With Quote
Old 09-22-2013, 05:09 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
http://www.ebay.com/itm/Big-Block-Ch...tr#ht_23wt_919
A set of these on my 468 would be much more affordable!
Old 09-22-2013, 09:46 PM   #15
deestrong71
If you can get them for 200, that would be a good price !
**Deestrong**
Old 09-22-2013, 10:26 PM   #16
ItsRandy
ItsRandy's Avatar
It's an Entropy radiator. http://www.entropyrad.com/ I bought it with 14" fans but after installation it was determined the 14" fans were inadequate. A 16" fan set with shroud was fabricated and Entropy just swapped them, I may have had to pay shipping.
Old 09-22-2013, 11:21 PM   #17
deestrong71
Nice looking headers Randy, I looked at those pretty seriously, but the headers I have know only have 4 inches clearance and decided to try the Sandersons, as they are a mid size header. They wont be below the frame, but unfortunately they only have 1 7/8 Primary tubes. Hopefully that wont hurt my performance too much.
**Deestrong**
Old 09-25-2013, 05:24 AM   #18
deestrong71
My Tranny got here today !
TCI Super Street Fighter
**Deestrong**
Old 09-26-2013, 08:45 PM   #19
deestrong71
Fitz you dont know what kind of Motor Mounts you used in your 572 install do you ?
**Deestrong**
Old 09-26-2013, 09:47 PM   #20
Fitz
Yes, I do. They were Energy Suspension Part Number: 71907
Old 10-03-2013, 08:30 PM   #21
deestrong71
Starting the Upgrade on the Fuel system.
Tank Out, Holley Electric pump mounted, Fuel regulator mounted and fuel lines
upgraded to AN lines.
**Deestrong**
