![]() Join Date: Aug 2013
Torsion lowering
I am looking to get down a few more inches out of my 61 Sub. It has Torsion susp and I have turned them down a bit but now the keys hang to low. I tried to reclock them but since they are 6 sided it is to much or a movement to reclock them. Any Ideas? Anyone know of any reclocked keys or keys that will fit from another vehicle?
Thanks for the help Adam |
Re: Torsion lowering
I think photos would help or maybe it is that I don't know what keys are.
Who Me?
I don't think you can move the keys to keep the truck low and those off the ground. I ran into the same issue and left them low. I think if the bar ends had 12 points instead of 6 it would be easier to re-index them for what you want.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I just lowered my 62 GMC and noticed the same thing. Does anyone know how the torsions are held into the control arms? Maybe they can be indexed differently from that end?
Posted via Mobile Device |
Guys, I don't think re-indexing the torsion bars is going to work... 6-sided, means each hex is 60 degrees. You'll never get things working by rotating one piece or the other 60 degrees.
I lowered mine by cranking it down, and I don't have any problem with anything hitting under the truck--and I drive my truck daily. Perhaps taller tires would be a solution for you? I've got 235/75/15 on mine. I'm eventually going to crank them back to stock height, and put drop spindles in. I don't bottom out on the suspension often, but it does happen. Plus, the funky geometry is hard on tires. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Drop spindles means disc conversion correct?
Thanks for the input Adam Posted via Mobile Device |
Hollister, CA.
![]() Join Date: Sep 2006
Have you thought about fabbing up your own keys ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
| Bookmarks |
