09-20-2013, 04:39 PM | #1 |
Banjo bolt torque
Well, i must be missing something i have 3 different books to reference to find a torque spec and i cant find it in ether of them, I'm looking for the torque spec for my front caliper banjo bolts that go thru the brake hose. Thanks!
P.S. Yes i tried a search before posting.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-20-2013, 04:55 PM | #2 |
Re: Banjo bolt torque
I don't know if there is a torque value or not for banjo bolts. I just tighten them, sometimes the washers don't seat correctly and tightening them more cures it, sometimes I have to use a different pair of copper washers to get them to seal. I'm probably wrong but I always tighten as necessary, have never measured a torque value for them. Keep in mind to use common sense, don't use a long bar to tighten which could possibly break them.
09-20-2013, 05:43 PM | #3 |
my gm factory service manual lists 22ft lbs for flex hose to caliper// it is located in with the brake specs
08-30-2014, 05:33 PM | #4 |
Hey guys, I know this is old but whole trying to bleed the calipers today from my cpp kit, I couldn't get one of the copper gaskets to seal against the caliper and I wound up snapping the banjo bolt in half while tightening it trying to get it to seal. Went to napa and got a new bolt and copper washers but haven't tried getting it yet.
The second pic shows the caliper side gasket. It appears to be squished to a taper. Wanted to get your expertise. |
08-30-2014, 08:00 PM | #5 |
Anyone?
08-30-2014, 10:40 PM | #6 |
By the looks of the washer I'd say the hole in the caliper is not square with the casting
08-30-2014, 10:45 PM | #7 |
That's what I think as well. Now I have to wait until cpp is open. Hopefully they aren't closed Monday for Labor Day.
Thanks for the reply. |
08-31-2014, 08:42 AM | #8 |
had the same problem with one of my CPP calipers i had to replace the caliper with one from Summit,problem solved
