09-20-2013, 05:38 PM | #1 |
Smaller Diameter Balancer?
I'm swapping a LS into my '66 C10 and also have No Limit's rack and pinion kit. I'm wanting to section the crossmember 1.5" but the pulley will hit the rack. Are there any smaller diameter balancers, factory or aftermarket? I google searched but didn't find anything. I currently have a 5.3 for mock up but will be swapping to a LS2 eventually. Do LS2's have the same 7 5/8" diameter balancer?
I know the rack is in crooked, I just threw it together quick to check the rough clearances and forgot the passenger side mount bushing.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-20-2013, 11:03 PM | #2 |
Re: Smaller Diameter Balancer?
Is there no way to move that hose?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-21-2013, 02:08 AM | #3 |
Old member
I don't see a problem with how it sits now other than the plastic hose and u should be able to move it. All u need is for the pulley to clear the rack by just enough to get the belt off when need be.
09-21-2013, 07:03 AM | #4 |
The hose can be relocated to the bottom side; my problem is that I want to raise the crossmember 1.5" and there is only 1 1/4" clearance now.
09-21-2013, 02:23 PM | #5 |
meowMEOWmeowMEOW
You would need to section UP, then notch DOWN.
So pancake the crossmember, then come back and clearance notch the top. As for your rack and pinion...can't really notch that....not sure what to say.
09-21-2013, 04:14 PM | #6 |
Yeah that's the plan, I'm going to notch the frame rails to raise the crossmember, then make a notch for the oil pan. I found 25% under drive pulleys at Summit Racing that are smaller, and I also found that Vette pulley only stock out from the front cover 2 1/8". I'll try that.
09-21-2013, 06:34 PM | #7 |
why not do a "z" instead of the section crossmember?.....could save alot of problems with balancer/pulley and r&p steering geometry?....... most LS pulley set ups run a normal balancer like a ATI or fluidamper, and then a billet crank pulley....not sure how much smaller in diameter the pulley's are....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
09-21-2013, 08:02 PM | #8 | |
09-22-2013, 01:36 AM | #9 |
meowMEOWmeowMEOW
careful with the aftermarket stuff and vette stuff, as the cars and vette's have a different snout length so the offset on all the front accessories needs to match.
09-22-2013, 02:18 PM | #10 |
actually the motor and trans stay at the same height in relation to the ground with a "z"....the front end gets lower....but whatever, if you don't want to cut it up fine, it's your truck....I am also thinking of buying the no-limt r&p kit...I'm guessing you haven't tried it out yet?
09-22-2013, 02:59 PM | #11 | |
I just got it in this past Monday and mocked it up Friday after work. It'll be a long time before I get any miles on it. So far the mounting bracket fits like a glove, and everything looks to be of good quality.
