Yep, Another header question.
Here's what I'm dealing with:
![]() Ive read a few header threads and still am not quite clear. I want long tube headers but would like the collector to be above the bottom of the framerail so i can tuck my exhaust up and run it through the rear crossmember. I've heard Camaro headers but which one? any options out there? |
![]() Join Date: May 2012
Re: Yep, Another header question.
I used 72 hooker chevelle headers on my big block.They tucked in the frame nice.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
I should have added this truck has a 327 small block..
60-66 Nut
![]() ![]() Join Date: Mar 2007
You could possiblr use small block Chevelle headers, which should be above the bottom of the frame, However those will not work if you still have the original bellhousing crossmember.
CaptainFab,
Thanks, I do not have the original crossmember. My truck has a 700r4 trans with a tailshaft crossmember. I'll look into those.. |
OK, I picked up a set of 69 camaro headers from a buddy yesterday so we could see if they would tuck up above the bottom of the frame on my 66 c10.
Before I start dismantling my truck I would like to ask if some one has a set of long tube headers for a 60-66 V8 truck hanging around could I get a measurement just to see what the over all height is. I stood the header up against a stool and measure from the ground up to the bolt hole at the #2 cylinder on the passenger side header. I came up with 16 11/16". Thanks for the help guys... ![]() |
Bump, Anyone?
![]() Join Date: Mar 2012
I'm watching this thread also. If you end up trying them let me know. my Headers scrap bad.
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
Looks like thats what I'm gonna have to do , I can't believe no one has a set of truck headers hanging around that can take a minute and grab a measurement for me....
I can when I get back home this weekend
ok, so for the last hour I have been cross referencing threads and found this statement: http://67-72chevytrucks.com/vboard/s...28&postcount=8
that led me to this post: http://67-72chevytrucks.com/vboard/s...&postcount=281 this make reference to using 68-71 Camaro headers. I believe they will work. |
