09-20-2013, 08:02 PM | #1 |
Tie rod end p/n 65 chevy swb stepside
Brand name is Chassis parts
Part store is Advance Tie rod end closest to the tire Tie Rod Ends from advance auto Part Number is DW-ES350L I got home and checked them beside my old ones and the new ones seem too long.I called back at advance and the guy swears it's the right part.I need the one that's closest to tire and I have a 65 SWB step side.can someone tell me which part number I need from advance, O'Reilly,s or AutoZone I would greatly appreciate it.I'm planning on putting them on tomorrow if I can find them. Posted via Mobile Device |
09-20-2013, 08:17 PM | #2 |
67-72 parts collector,…
Re: Tie rod end p/n 65 chevy swb stepside
Is your truck equipped with stock drum brakes up front or has it been converted to disc brakes?
09-20-2013, 08:20 PM | #3 |
It has drums sir
09-20-2013, 08:23 PM | #4 |
Stock is the same number,...
http://www.oreillyauto.com/site/c/de...3448&ppt=C0203
09-20-2013, 08:44 PM | #5 |
I swear when I compaired them the orig was shorter.they dont look alike but ill try them tomorrow and see
09-20-2013, 09:26 PM | #6 |
This new tie rod that goes by the tire looks like the its the same length as the rear tie rod.it looks like its a inner instead of outter(next to the tire) rod. Has anyone replaced tie rods and noticed they are longer than the stock ones than the truck originally had.The part number is right but the part its self looks wrong.only thing I can thing I can think of is either my suspension has been changed to a later model or the new part is improved
09-20-2013, 09:30 PM | #7 |
Whoever worked on it last may have put the tie rod assy in backwards, inner rod to the outside. One is right thread and one is left so that you can turn the sleeve and adjust it in and out. Doesn't really matter which way it goes functionally until you start repacing stuff.
09-20-2013, 09:32 PM | #8 |
Got any pics of your suspension?
09-20-2013, 09:54 PM | #9 |
Ill get pics tomorrow.id also like to get them done tomorrow
09-20-2013, 10:01 PM | #10 |
This is what my tie rods look like. Is it possible that the p/o used earlier model Chevy truck tie rods on it
http://www.ecklerstrucks.com/chevy-t...1960-1962.html http://www.ecklerstrucks.com/chevy-t...1963-1964.html Posted via Mobile Device |
09-20-2013, 10:17 PM | #11 |
Could your '65 be on a '63-'64 frame?
60-62 trucks had torsion bar front suspension.
09-20-2013, 10:22 PM | #12 |
I have coils in front
09-20-2013, 10:44 PM | #13 |
Im about 90% sure I need 63-64 tie rod ends.maybe I have a early 65 or the po put them on but they look
09-21-2013, 03:11 PM | #14 |
Have them look up the INNER tie rod and compare it to that- like mentioned before, it's not uncommon for them to have been installed backwards at some time- it does not effect how they work, tho.
09-21-2013, 03:17 PM | #15 |
http://contentinfo.autozone.com/znet...S323L/image/4/
This is the ES323L outer tie rod for a 1964 C 10 2WD The matching inner is an ES 678 The 1965-66 uses the ES350L outer and ES370R inner |
