Old 09-21-2013, 01:54 PM   #1
swamp rat
swamp rat's Avatar
Fill plug location.
On my Eaton Ho52/72 (which ever it is)
I was looking at a pic of before i started working on my truck and the plug is below centerline, i have seen a lot of pic's from this forum also showing the plug in the same position. since then i have also seen pic's of cover flipped 180 with the plug above the centerline..
Looking at a pic with the plug below centerline it sure looks to me that the diff would not have sufficient lubrication for the wheel hubs unless i was constantly turning corners.... I'm questioning if these covers were installed correctly, How does the wheel hubs receive sufficient lubrication of the level is so low it only reaches the bearings during the G force of cornering??
Anybody have a picture/print from a factory manual showing the cover???
Here's 2 links showing both
http://67-72chevytrucks.com/vboard/s...1&postcount=30
http://67-72chevytrucks.com/vboard/s...2&postcount=12
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-21-2013, 03:19 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Fill plug location.
Like you, I've seen it both ways. Full floating vs semi floating? My HO52 is long gone and the 14 bolt, I have, doesn't have a fill plug in the cover but on the side. Kind-of mid level on the pinion. Which isn't much above the lowest part of the tube
I always pack my bearings with grease anyway. Just like the front.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-23-2013, 02:19 PM   #3
kwmech
The second pic is correct, oil level should be with the bottom of the inside of the tube or very slightly higher
Old 09-23-2013, 09:45 PM   #4
swamp rat
swamp rat's Avatar
Ya know i wish i could find just 1 factory picture showing the rear cover on this thing.
It may be incorrect but i decided to install my cover with the plug at the top, I figure with the vent in the housing pressure won't be a problem, and i can always use my finger to gauge the level and keep it a bit lower than the plug.
Besides, my plug was a leaker and i don't know if my home made gasket will be any better.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-27-2013, 06:37 PM   #5
swamp rat
swamp rat's Avatar
Well, i found out this does not work, the plug hits the ring gear, cant figure out how in the first pic and the others I have seen that it worked unless they had a super thick gasket, or maybe they also had to flip it over? Bottom line don't try this at home.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-27-2013, 08:39 PM   #6
vectorit
What?
vectorit's Avatar
Hmm.. Here is mine, and been in this position as long as I can remember.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-27-2013, 09:11 PM   #7
swamp rat
swamp rat's Avatar
Yep thats the stock location, i was considering doing a 180 and adding a little extra lube, but not clear to the top of the plug..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-28-2013, 01:09 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I still don't understand why you want to overfill the diff. The factory level has worked for many years, in countless applications.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-28-2013, 02:25 AM   #9
swamp rat
swamp rat's Avatar
I think mainly because my wheel bearings looked like total crap when i took them out with the level maintained, also, when i look at the level plug to me it looks like the gear oil does not reach the bearings unless the enertia from turning a corner forces the oil to the hub. Yea i know there are thousands and thousands out there, but when i seen a few picks with them turned 180 i just thought why not. End of story.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-28-2013, 04:08 AM   #10
jjzepplin
jjzepplin's Avatar
I clocked my rear end a bit and the pinion did not look like it was going to get oil so I just screwed in a 90 degree pipe fitting and pointed it upwards and added the extra lube and now the same plug goes in that fitting. Been that way for ten years, no problems. 14 bolt though but I don't see why you couldn't do the same thing.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-28-2013, 11:23 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thanks for the explanation. I wonder if there could be some other reason your bearings looked bad? My '72 still has its original bearings. They appear to be well-oiled and still looked good last year.
- Mike -
RIP El Jay
Old 09-28-2013, 11:54 AM   #12
Bigdav160
Bigdav160's Avatar
My guess is, at some time, the rear oil got low. It wouldn't take much to starve the bearings.
I always pack my bearings with grease anyway. It works in the front. Eventually the gear oil will wash it away but at least the bearings are protected on the initial roll.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-29-2013, 01:13 AM   #13
swamp rat
swamp rat's Avatar
I appreciate the thought about the 90 deg elbow, the Eaton unfortunately is not NPT, its a fine thread, have yet to measure it with my thread gauge to figure out exactly what it is, haven't had time to deal with it, too busy with the lift kit.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-29-2013, 01:15 AM   #14
swamp rat
swamp rat's Avatar
The only explanation i could think of is if someone changed them out they may have installed them without packing them. Thanks for the reply!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-29-2013, 01:21 AM   #15
swamp rat
swamp rat's Avatar
Well i absolutely packed mine the old fashioned way working the grease in using the palm of my hand and put a coating on the races too, i would be much less concerned if the hubs were isolated so the grease didn't wash away tho.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
