2.5/4 on 20's
Factory front sway bar?
I'm thinking of buying a sway bar from a guy here, but I don't want to pay to much.
How much is a used 72 sway bar worth. It's missing the bushings. Thanks
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck. 1965 Mustang Vert - Shelby Clone 2005 Dodge SRT-10 My Old 72 SWB |
Wow, tough call. Its just a funny shaped piece of steel rod but prices range a lot. When I go to the boneyard to pull a part I always ask the guy "How much would you charge for this or that?" Before that I yanked a sway bar from a 67-72, even got the guy out there w/ a torch to cut out the rivets for me. He then charged me $75 Cdn. I guess I had to pay a little extra for the help. But I still figure it was a bit steep. I then had to go buy the bushings etc.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
![]() Join Date: Sep 2001
I bought one for $50 but that included a little $ for cutting it off the truck. I'd say $25 or $30 if you have to cut it off yourself.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
If you can't get the 'yard to cut off the brackets for a reasonable amount, unbolt everything you can and then go to the GM dealer and order pn 6271375. I paid just under $10 each for the brackets and $10 to the 'yard for the bar. Best $30 I've spent on my truck so far!!
BTW, the bars are the same from 67 to 87 and even later on Subs. The heavier trucks have a larger bar if you want it even stiffer than stock. Good Luck
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
you can buy 'em all day around here for $10 - $20 ... you pull it
Not Dusti,just Bob
I think I paid about $15-20 for mine at the yard,the guy just gave me a price for all the stuff I had got that day and that sounded good,had to buy new brackets and bushings also.
72 cheyenne super 1/2ton 89 camaro |
2.5/4 on 20's
found out on the way home it was $16 if I pull it myself. I think that is fair enough.
Thanks for all the replies. ![]()
Not Dusti,just Bob
$16 sounds good,what is it off? there are different sizes of bars.
Make sure you get the correct bushing, the guys at the parts stores get all confused when you tell them you want a part for a 72 3/4 ton for your 70 1/2 ton
#9 | |
its all about the +6 inches
He said " I don't think I wanna even know about that". You shoulda seen his face when i told thim the whole engine was in my truck!!! |
