Old 09-22-2013, 03:20 PM   #1
ozbowhunter
one wire i just cant work out what its for
I have a couple of pics of a wire I cant find what its for the first shows the connector block it comes out of the other is the end anyone got an idea it is light green in color
and as you can see i have a patch to fix in the top of the fire wall never ends does it lol
ozbowhunter is offline   Reply With Quote
Old 09-22-2013, 03:34 PM   #2
frog210
Re: one wire i just cant work out what its for
Horn, Temperature sensor maybe...
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-22-2013, 03:36 PM   #3
Dead Parrot
Quick guess based on location, either for the fast idle AC solenoid or choke heat power.
Dead Parrot is offline   Reply With Quote
Old 09-22-2013, 03:53 PM   #4
slam59
I have one almost identical but black coming from firewall on mine and was wondering too about mine.
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 09-22-2013, 04:06 PM   #5
geezer#99
geezer#99's Avatar
Wiring diagrams! Search to your hearts content! Might have to blow them up a bit.
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Old 09-22-2013, 04:19 PM   #6
ozbowhunter
I was thinking something to do with the ac where is the fast idle solenoid ?
Old 09-22-2013, 04:38 PM   #7
ozbowhunter
ok had another look at all of this and the two wires coming out of the block are the dark green which runs to the AC compressor the light green which is the one I an trying to sort
I cannot find a connection for it any where the ac compressor has the dark green and an earth wire so im assuming this light green is the switch wire but to where it connects im lost will study the diagrams but if anyone has an idea please let me know
Old 09-22-2013, 05:09 PM   #8
ozbowhunter
just went through the diagrams and there's no ac wiring listed man this is getting annoying lol
Old 09-22-2013, 05:21 PM   #9
geezer#99
geezer#99's Avatar
Dark green to a/c switch at the compressor. Light green to high idle solenoid on the carb. Like on my carb.
Old 09-22-2013, 05:42 PM   #10
y5mgisi
Second Chance Program
y5mgisi's Avatar
Yep A/C related, and as geezer said, that one likely goes to the high idle solenoid as he has pictured.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-22-2013, 05:59 PM   #11
ozbowhunter
thankyou
if mine does not have that solenoid as it has had the engine swapped before I got it is it something I can add ?
Old 09-22-2013, 06:37 PM   #12
geezer#99
geezer#99's Avatar
You sure can! Look on evilbay maybe. Or auto parts store or junkyard (aka experienced parts) emporiums.
Old 09-22-2013, 09:17 PM   #13
ozbowhunter
is this a ground contact switch? if so can I check the system by making contact with the engine ground ?
Old 09-23-2013, 02:23 PM   #14
ozbowhunter
am I right in thinking that without this solenoid the system wont work ? as in that the compressor clutch wont click on with out this contact
Old 09-24-2013, 09:57 AM   #15
hatzie
Moderator
hatzie's Avatar
Nope. It'll work just fine. The AC throttle solenoid kicks up the idle so the engine doesn't stall at every light with the AC switched on.
You can find GM wiring diagrams for your rig in my signature.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-24-2013, 12:47 PM   #16
ozbowhunter
thanks
now im stumped the system wont kick on at all the compressor clutch wont click on when the switch is moved to aircon any ideas where to start looking ?
Old 09-24-2013, 04:19 PM   #17
Willowrun
Willowrun's Avatar
There is a low pressure sensor for the AC on the passenger side AC plumbing that has two wires that run to the AC pump. Unplug the connector going in to the sensor and when the engine is running and the AC in the on position take a paperclip or something similar and jumper the two posts of the connector that was plugged into the low pressure sensor. If your AC clutch engages you know that your clutch works but either your system has leaked its charge or you have a bad low pressure sensor. That is the first thing i usually do when a clutch doesn't engage and it is typically because of a non-charged system.....a leak somewhere.
Old 09-24-2013, 06:56 PM   #18
ozbowhunter
thanks I think I will be able to get in and sort it if there is a leak what's the best fix ?
is there a sealer for the system ? thank for all your help
