09-22-2013, 03:28 PM | #1 |
brake help fast
I Have a 1971 c20 pickup truck 2wd. It has a dana axle but I am not sure what size rear drums and shoes I need and I don't have to time take it all apart and look. I was hoping someone might be able to help me out on this. Thanks!
09-22-2013, 05:34 PM | #2 |
425hp409
Re: brake help fast
There are two sizes of rear shoes, depending on whether you have leaf or coil springs.
For coil you should have 11 5/32 X 2 3/4" Napa part # UP248R For leaf you should have 12 X 2/12", Napa part # UP419R Posted via Mobile Device
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
09-22-2013, 08:10 PM | #3 | |
Re: brake help fast
Ok thank you and would you happen to know what the drum size I need for those as well? I have leaf springs |
09-22-2013, 08:24 PM | #4 | |
Re: brake help fast
I have a C20 with coil springs and my drums cleaned up with very little metal removal. It's not easy to find a shop that can do this. An automotive drum lathe won't do it and a shop that does big trucks will tell you the drum is too small for their equipment. I found a shop in Houston that does equipment like forklifts. Both drums $130.
Gale Gorman '54 3100 '67 C20 stepside |
09-22-2013, 08:32 PM | #5 | |
Re: brake help fast
09-22-2013, 11:58 PM | #6 | |
425hp409
Re: brake help fast
09-23-2013, 09:50 AM | #7 |
Re: brake help fast
That wasn't what I found. The problem was the hub. This is a C20.
09-23-2013, 06:46 PM | #8 |
Re: brake help fast
Does anyone know where I can get a diagram or video online of how to remove the drum for this truck?
09-23-2013, 07:12 PM | #9 | |
425hp409
Re: brake help fast
1. remove the wheel and tire 2. remove the 8 bolts that hold the axle, remove the axle by pulling straight out 3. Disengage the tang of the nut lock from slot or flat of lock nut, then remove lock nut from housing tube using appropriate tool 4. If there is another nut, remove it at this time. 5. Pull hub and drum assembly from axle housing
09-23-2013, 07:43 PM | #10 |
Re: brake help fast
I have never done the rear brakes before so yes I am a beginner at that. I pulled the axle shaft out but I now I need to pull a huge nut off. I am not sure of the size but is looks to bee around 60mm, I will post a pic. I know there are a lot of other locking rings and what not after that ( I think around 6 or so rings to pull off but I'm not sure) and yes I should probably hire someone but I am more of a do it yourself and figure it out hand of person lol.
I just want to know the exact size of the nut that is on there before I buy a socket and pull it off. If anyone knows what size. Oh and just to give some more info on the truck it is a 1971 c20 pickup fleetside 2wd 3/4 ton with 8 lug wheels and a 400 big block. Everything is original. Any help would be greatly appreciated. |
09-23-2013, 07:48 PM | #11 |
Re: brake help fast
here is where I am at
09-23-2013, 07:55 PM | #12 |
Re: brake help fast
There are 2 flat head screws holding the drum to the hub, remove those, slide the drum off if they are not embedded into the drum from scoring.
the screws will be in between a couple of the studs in the same bolt circle, unless the have been removed and clocked on differently. also, you shouldn't have to touch those nuts in the pic unless you have 90 wt. on the shoes. Another thing, with the leaf spring assy. you have a dana 60 axle, and with the big block should have a 3.54 gear ratio and a power-loc diff |
09-23-2013, 09:27 PM | #13 |
Re: brake help fast
This might help with the job maybe not with your question..
http://67-72chevytrucks.com/vboard/s...d.php?t=200268
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-23-2013, 09:30 PM | #14 | |
425hp409
Re: brake help fast
09-23-2013, 09:33 PM | #15 |
Re: brake help fast
