Old 07-08-2003, 05:11 PM   #1
78chevstepside
78chevstepside's Avatar
headers and starters
Anyone have a solution for heat on the starter and solenoid from headers? My 78 wont start after even short trips. I replaced the starter and solenoid with a lifetime warranty unit. I have a heat shield on the soleniod(doesnt help). I have had headers for a long time and it always started slow when hot(but it always started). I have heavy duty battery cables, recently new battery.The ford solenoid trick doesnt work niether my brother -in-law wasted alot of time on the idea.jay
78chevstepside is offline   Reply With Quote
Old 07-08-2003, 08:44 PM   #2
gldevall
gldevall's Avatar
How you tried a mini starter?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 07-09-2003, 01:11 AM   #3
DrMaserati
Village Curmudgeon
Is your starter shimmed for proper flywheel engagement? It may be binding, and have nothing to do with heat.
JP
78 Chevy K30 duallie, 454, TH400
78 IH Scout II, 4X4, 345, 727TF
76 IH Scout II, 4X4, 345, 727TF
65 IH 1200C pickup, 4X4, 345, 4 spd
48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck)
"Life is too short to drink cheap beer." Harry S. Truman
DrMaserati is offline   Reply With Quote
Old 07-09-2003, 04:36 AM   #4
Mike76251
That is a strange one....
I have a NAPA (USA rebuilt) full size starter and one of those Moroso heat shields and my headers never overheat the starter.
Mike76251 is offline   Reply With Quote
Old 07-09-2003, 04:18 PM   #5
78chevstepside
IT starts fine when cold. The hotter the engine gets the harder it starts.( till it wont turn over till it cools down). Iam positive its shimed just fine. A small starter may be the trick. I f a starter wasnt shimed right iam guessing it would malfunction all the time.
jay
Old 07-09-2003, 05:55 PM   #6
44th Miss Inf
78 Step,
The Ford solenoid should have worked. It's about a 30 minute job, at the most, and no need to buy the expensive 'kits' to do it. I run them on almost all of my vehicles. (Even my BBC with mini starter)
It takes 4 amps to energize where the GM hot takes up to 60. Also it doesn't have a 'hot' wire down by your headers.
Also, even if it is a "lifetime" warranty starter, most places just replace what needs to be replaced to get them going. Find you a 'hole in the wall' starter/alternator place, and tell him to put some of the better components in it instead of the standard rebuild stuff.
Good luck.
Virgil
44th Miss Inf is offline   Reply With Quote
Old 07-09-2003, 06:47 PM   #7
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
What about wrapping the headers with that header wrap?
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 07-09-2003, 07:39 PM   #8
allthrtl
Available for Adoption
allthrtl's Avatar
I don't personally think it's a starter issue.....I've run these trucks with headers for years and never had any problems....Look harder, I think you have other problems....
Michael
1983 C10 SWB 2001 Silverado SWB 1995 Corvette
allthrtl is offline   Reply With Quote
Old 07-09-2003, 10:32 PM   #9
454Sub
I've been running headers on my 454 Suburban for a couple years, absolutely no problem, and this is in Houston TX and with a hot cam.
What I suspect is a wiring problem with your truck. I had a Grand National that wouldn't start after just a few minutes of running. After replacing the starter and solenoid I traced the wires. Turned out someone had wired in a shut-off switch as an anti-theft measure (ironically, it turned out to have been a stolen car). They used 14 gauge wire, and added about 6 feet to the lead to the solenoid. So there wasn't enough current to jump the solenoid if the engine was even moderately warm. May not be your exact problem but check all the wiring to you starter and solenoid, including the starter switch in the column. Any crimped or soldered joints are suspicious, and any added wire should be scrutinized. A GM truck with headers should start easily every time, headers or not.
Jeff
454Sub is offline   Reply With Quote
Old 07-10-2003, 03:14 AM   #10
DrMaserati
Village Curmudgeon
Originally posted by 78chevstepside
I f a starter wasnt shimed right iam guessing it would malfunction all the time. jay
Not necessarily. When things get hot they expand, and tolerances close up. It may have just enough clearance not to bind when cold. An easy test would be to loosen the starter slightly when it's hot and try it. If that works, then you need more shim.
And I think 454Sub has some very good suggestions as well.
Old 07-10-2003, 04:49 AM   #11
CustomChevy
Well, you can do 2 things to remedy your problem.
1. Header wrap (i.e. DEI-010110 at Summit)
2. Starter wrap (i.e. DEI-010402 at Summit)
Those are by Design Engineering. It's just one example, there are numerous brands out there. Good luck!!
CustomChevy is offline   Reply With Quote
Old 07-10-2003, 08:13 AM   #12
1FaastC10
1FaastC10's Avatar
check the battery. i had a similar problem with my C10, turned out to be dead cells in the battery.
1FaastC10 is offline   Reply With Quote
Old 07-10-2003, 10:59 AM   #13
BigRed
I agree with 44 Miss Inf about the remote solenoid. I put a couple links in this thread that would tell you how to easily install one. Not an expensive or time consuming fix to see if that's your problem.
http://67-72chevytrucks.com/vboard/s...threadid=59169
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 07-10-2003, 04:54 PM   #14
44th Miss Inf
BigRed,
I use the one from the Street Rod link. That way only 1 wire going to the starter, and it is not energized except during cranking.
Virgil
Old 07-10-2003, 05:24 PM   #15
78chevstepside
I fixed the problem. I went and bought a heat sheild insulation wrap. I installed that and it improved some but not all the way. Then i really started lookin. I noticed that the ground strap for the motor( not the main ground on the battery) was melted in two from cranking on the starter when it was too hot. So I replaced that and it cured the problem. Maybe that was the only problem to start with. Thanks for your peoples help :p jay
Old 07-10-2003, 05:52 PM   #16
44th Miss Inf
Glad to hear that you are back up and running. Sorry for getting off topic with the remote solenoid .
Virgil
