Old 09-22-2013, 10:26 PM   #1
HOTFUN
HOTFUN's Avatar
What type of hose clamps from factory 66 327 bypass hose?
I believe they could have been the half clamp style but maybe even a tower clamp? I have only seen screw clamps on the few I've seen. I know the heater hose connections used the wire clamps and the metal upper hose used tower clamps. Please let me know I need to come up with a pair and they appear to have to work on a 1.5 hose for the thermostat to water pump GM bypass hose. Thanks
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 09-23-2013, 08:39 AM   #2
HOTFUN
HOTFUN's Avatar
Re: What type of hose clamps from factory 66 327 bypass hose?
Witteck branded tower clamps is what is what the upper radiator hose had on mine. Corvettes in the 60's have this same style clamps and the Vette places sell them in sets. Looks like the bypass hose on them was that half clamp style with the screw and square nut on the side maybe around a #14 style of Witteck clamp? May have to order a kit just to get the two bypass hose clamps. Anyone have a picture of an original survivor 65-66 327 truck engine?
'72 GMC K2500 4x4
Old 09-23-2013, 02:59 PM   #3
ray_mcavoy
I belive they originally used the tower clamps on that bypass hose.
This is a pic I took of a local farmer's C60 with a fairly original 327. Some of the hose clamps are worm gear type replacements but there is one original looking tower clamp left on the bypass hose.
And here is another pic that I saved for reference from an old ebay listing of a 327 that was pulled from a 65 or 66 C60. It appears to have tower clamps on the bypass hoses.
Although both of these examples are of the medium duty version with the dual bypass hoses, I have a feeling that the single bypass hose on the 10-30 series truck 327's would use the same style clamps.
ray_mcavoy is offline   Reply With Quote
Old 09-23-2013, 07:39 PM   #4
HOTFUN
HOTFUN's Avatar
That looks about right too me also. Thanks for the picture. Now finding the right size will be the next task. Thanks, Mark
'72 GMC K2500 4x4
Old 09-23-2013, 09:34 PM   #5
yelmer
just to make things confusing , my truck 327 had wire clamps on bypass hose?
yelmer is offline   Reply With Quote
Old 09-25-2013, 06:22 PM   #6
ray_mcavoy
Interesting ... I wonder if this is something that changed based on the build date. For example, I know GM eventually switched from wire clamps to tower clamps on many heater hoses ... sometime around 68 I think.
While we're on the subject of the 327 bypass hose, does anyone know if the bypass hole that connects the water pump to the passenger side head was left open? Or was it blocked off on these engines?
Old 09-26-2013, 12:21 AM   #7
HOTFUN
HOTFUN's Avatar
I went ahead and ordered 2 Wittek bypass hose clamps that according to the Corvette vendors is correct for 63-68 GM cars and trucks with bypass hose. They show on the Vette in 65=66 the red color wire clamps on the 3/4 heater hose ends, the gold wire clamps on the 5/8ths heater hose ends, the side screw/nut Wittek brand bypass hose clamps one both ends and then the Wittek brand tower clamps on the radiator hoses. I think that should be right but if not it will be NCRS correct anyway. Thanks for all the assistance here and pictures.
'72 GMC K2500 4x4
Old 09-26-2013, 12:26 PM   #8
61K10
61K10's Avatar
could you post a pic of your by-pass hose? 66 1/2 ton?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-26-2013, 01:18 PM   #9
HOTFUN
HOTFUN's Avatar
This is the ebay link for the bypass hose clamps I bought for my 327 PU. I am on my way out of town for the big auction now so I will post pictures when I get the clamps and install the hose later next week.
http://www.ebay.com/itm/200967242290...84.m1497.l2648
'72 GMC K2500 4x4
