Old 09-23-2013, 12:44 PM   #1
54blackhornet
54blackhornet's Avatar
SM -465 Shifter Removal ?
I know that you are supposed to push down and turn it counterclockwise , but I need a photo of what you push down ! I can't seem to figure this one out ? Thanks for the help !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 09-23-2013, 01:02 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: SM -465 Shifter Removal ?
I don't have a photo, but you push down and turn the stamped steel retainer (that the shifter sticks up through).
If you look at the case you will see a cast iron tower (part of the trans case); there are two split pins in that tower. The goal is to push down on that steel retainer (it is spring loaded "up") and rotate to disengage the slots in the retainer from those split pins.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-23-2013, 01:21 PM   #3
john
member #16
john's Avatar
Some penetrating oil around the retainer won't hurt anything. They get gunk and grime built up over the years.
john is offline   Reply With Quote
Old 09-23-2013, 01:28 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
here is a photo of it disengaged. This is what Keith's post is explaining.
Push down and twist.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-23-2013, 03:09 PM   #5
Keith Seymore
Perfect. Better than a thousand words.
Thank you -
K
1979-1986
1986 - 2019
Old 09-23-2013, 03:22 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Thank you -
K
Just an addition for a great explanation sir.
Thank you. I hope it helps the end user
Old 09-23-2013, 03:43 PM   #7
54blackhornet
Thanks a lot guy's that picture explains it perfectly ! I can see how it is held in now! Also I learned that this trans loves 50W Mobil 1 better then 80 /90 gear oil ? If you google SM465 you get all sorts of conflicting info on lubrication type for it and the NP-205 ? Thanks Again.....
71 C-20
07 Magnum RT AWD
