09-23-2013, 07:00 PM | #1 |
55-59 Pocket kit
Has any seen or used a pocket kit on a truck, would it work ok?
Larry Brown North Texas My 1956 Build - Huff Truck http://67-72chevytrucks.com/vboard/s...48#post6308448 |
09-23-2013, 11:31 PM | #2 |
Re: 55-59 Pocket kit
What's the original application for that kit? It appears to be a setup to move rear springs to the inside of their normal position on cars like Novas that don't have separate frames on the rear half.
09-24-2013, 12:37 AM | #3 |
Never heard of a "pocket kit" so I don't know what those parts do but they appear to be leaf spring related.
Check out JJ's (Chuckdriver) build thread. He used a kit to move his leaf springs UNDER the frame, not inside.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-24-2013, 08:02 AM | #4 |
That kit is for a 55-57 car, and yes it moves the spring under the frame.
09-24-2013, 08:14 AM | #5 |
The idea of the pocket kit is to get the springs up higher, because they sit directly under the 55-57 passenger car frame. On the truck, your springs are next to the frame, so there's no reason to use a pocket (plus, there's no kickup on the truck frame).
If you want to lower the truck, then do an axle flip kit, but if you're looking for more tire clearance, a 4-link kit might suit your needs better. |
09-24-2013, 08:41 AM | #6 |
You don't need a kit to move the rear springs under the frame on a truck. All you need are front spring mounts. They bolt to the rear and maintain the exact center to center distance with a couple of simple mods and drilling a couple of holes. Gives you plenty of room for tires.
09-24-2013, 09:04 AM | #7 | |
I sent you a PM
