Old 09-24-2013, 03:31 AM   #1
Andy4639
Old member
Andy4639's Avatar
Wink 3am and can't sleep
Well I can't sleep and been thinking about this motor swap.
I like to do things myself and like the part about building something with my own hands. So
I think I've decided to do this swap myself. I found a engine hoist for $125.00. This has been my biggest problem. I had no way to remove/install the engines. So if I buy the hoist I can work on it anytime I want here at the house and take my time cleaning & painting up the new LSx motor while I have it out. I can store the hood and other parts in my enclosed trailer out back. I think I can get the motors out and in with the grille left in place. I hope! I may just as well take the whole front out of it though would make it much easier to work on it I guess.
I will be selling the 305HO TPI/700R4 once it's out. This will be a complete motor/trans combo that has Street & performance wiring and computer setup.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-24-2013, 04:45 AM   #2
w4625
Re: 3am and can't sleep
How much for the 700r4? I have a friend that is looking for one for his 65 Chev
Impala.
w4625 is offline   Reply With Quote
Old 09-24-2013, 07:04 AM   #3
Indian113
Indian113's Avatar
Andy, when I did my S10 I took the front end off as it made it easier to install my motor and trans. I had it in and out about 8 times before I buttoned it up. I imagine you will have more room than me but it was nice not to have to bend over a fender all the time!
Indian113 is offline   Reply With Quote
Old 09-24-2013, 07:38 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: 3am and can't sleep
The motor runs fine just has some blow by and it's just not what I want anymore. Want some more HP! It's been a good combo for 20 years but it's time to move on. It still has 80lbs of oil pressure when running and the transmission shifts fine no problems with it at all. I was going to run the 700r4 but found the combo so just went with it. I've had both cooler's on the trans the whole time.
Yea I think I'm going to leave the fenders on it and just pull the front off haven't looked that close at it yet. Maybe better to take the fender's off though maybe less unbolting over the long run. I'll decide when I start.
I'll start a motor swap thread when I do start.
Man I hope I can pull this off!
Old 09-24-2013, 07:53 AM   #5
jjzepplin
jjzepplin's Avatar
I like to pull the whole front clip so I don't damage it. These grills are not easy to come by and one tiny ding would just pi$$ me off and keep me up til 3am cursing myself and I just don't deserve it.
That and my back just isn't what it used to be.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-24-2013, 11:03 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you're going to leave the front in place consider getting a Load leveler for the hoist. Its only about $20 and lets you angle the load so you can "stab" the tranny tailshaft down into the engine bay, and angle the engine in place. It was a lifesaver with my swap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-24-2013, 11:47 AM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: 3am and can't sleep
I plan to pull the front end off just not the fender's at this point and time.
Old 09-24-2013, 06:01 PM   #8
Billett
Billett's Avatar
I pulled the whole front clip and used the load leveler. With all of it bare I only had to drop it in once and then I could work around it inside the engine bay. Not to mention it isn't exactly time consuming to pull those few extra pieces off. Its maybe a total of 30 bolts for the whole front clip. The problem is getting new bolts once your old ones snap haha
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 09-24-2013, 06:31 PM   #9
mooseknuckles
mooseknuckles's Avatar
just pull the whole front clip off, you'll be glad you did.....if you can swap out a smallblock you can do an ls swap!.. just do your homework and you won't have any "surprises"......
mooseknuckles is offline   Reply With Quote
Old 10-04-2013, 03:14 AM   #10
65 wonton
Andy, I'm confused. Not too hard these days, but you opened your swap thread with the price of a HF hoist ($195 IIRC) included in your cost and showed pictures of it. Then later you talked about not having one and now in this thread, you talk about not having one, again.
Dave.
65 wonton is offline   Reply With Quote
Old 10-04-2013, 11:51 AM   #11
jorgensensc
jorgensensc's Avatar
Take my word for it, take the whole front clip off. I just took the front grill/ core support out of mine, left the hood and fenders on. It was more work and more of a pain in the arse to do it that way than if I would have just pulled the whole front clip off.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-06-2013, 03:24 AM   #12
softballnrd27
Always a work in progress
softballnrd27's Avatar
Yes, it is much easier to take the whole front clip off. It allows you to see and get into places you jsut can't get into with the front clip on.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 10-06-2013, 10:29 AM   #13
ls1nova71
ls1nova71's Avatar
Its really hard to spread the fenders apart enough to get the core support out. I wouldn't try it on a truck with nice paint. Pull the whole clip, but do know they are front heavy and will flip forward if you're not ready for it. Ask me how I know...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-07-2013, 11:29 PM   #14
71chevystep4x4
71chevystep4x4's Avatar
I've done 3 swaps on my truck, first two taking whole clip off. Third time I didn't have any help, so I decided to remove the grill and core support, WHAT A PAIN IN THE ASS!!!! Besides, with a swap like this, you gotta have the room to work on stuff.
71chevystep4x4 is offline   Reply With Quote
