09-24-2013, 08:30 AM | #1 |
Upper Fender mounts
Hi guys,
Working on my 56 GMC again trying to get front sheet metal on, but ran into a little snag. The upper fender mounting location with the captured nuts are gone/torn out from my cab, does anyone make a weld in replacement? Thanks in advance
09 GMC 2500HD 6.6L 07 F-250 Super Duty V10 03 Chevy Tahoe 82 K5 blazer plow truck,currently under the knife 56 GMC stepside short,also in progress |
09-24-2013, 10:55 AM | #2 |
Re: Upper Fender mounts
I think you are looking at #10 on this page. http://www.lmctruck.com/icatalog/ca/full.aspx?Page=26
I'm not pushing buying from LMC as other vendors probably have the same piece but their breakdown drawing is easy to follow.
09-24-2013, 10:58 AM | #3 |
The other option would be to cut the damaged area out and make a patch with a new captured nut to weld in that spot.
09-24-2013, 11:07 AM | #4 |
McMaster-Carr calls them weld nuts and they have some that are close. I ended up making my own out of 3/8 flat stock since some of the frame was left and only the nut was missing.
09-24-2013, 07:48 PM | #5 |
Thanks guys.
Yes, that's the one in the LMC catalogue. My cowl is still minty, minus the captured nut, so maybe I will just try fabbing up a piece to weld on. Can anyone tell me roughly how tall the mount is on the cowl?
09-25-2013, 08:03 PM | #6 |
I had a couple of the cage nuts that were gone, the PO just used big washers and nuts. You can access all by removing the kick panel.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-25-2013, 08:07 PM | #7 |
Thanks,
Found a old big window cab at work today that the boss has stashed, and the mounts look to be roughly 1'' tall. Have a good starting point now.
