09-24-2013, 10:30 AM | #1 |
Chirping from rear end...
Recently, I started noticing a chirping sound that seems to be coming from the rear of the truck. It only occurs when the truck is rolling. The frequency changes with speed and stops all together when I press the brakes. Is there a wear indicator on the rear drum brakes that might be sounding? Any ideas would be helpful. Thanks in advance.
1972 C-10 Deluxe 350 V8 - 350TH ------------------------------ We're not the jet set We're the old Chevrolet set |
09-24-2013, 10:58 AM | #2 |
Cluster King
Re: Chirping from rear end...
No wear indicator for rear brakes. That is a good idea though. I would guess from the wording you use "chirp" that you have a u joint that is getting rusty inside. I am thinking you hear a " chirp chirp chirp" and the chirp gets faster as you get going faster and you probably don't hear it much when you are going around 40 - 50 mph but more at low speed.
I could be wrong but otherwise, jack it up and roll the rear tires and see what you come up with. It may also be a peice of rust on the brake backing plate or drum that has come loose.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
09-24-2013, 11:09 AM | #3 |
You're right. It's a "chirp chirp chirp" sounds. It's easiest to hear when decelerating/coasting, but stops when I press the brake. I did ride in the back of the truck and couldn't tell which side it was coming from which might point to the u-joints also.
I would think though that noisy u-joints would be unrelated to brakes being pressed so long as the truck's still rolling. Anyway, I'll give it look see. Thanks.
09-24-2013, 11:14 AM | #4 |
Active Member
Yeah, could be either of those -u joints or brakes.
Lube the joints (easier to do) if they have grease fittings and see if you notice a difference. Or raise rear axles and place on stand one side at a time. Start the truck to see if you can hear the noise. Just use caution and chock tires. If you don't hear the chirp, it might be ujoint since they usually act up when under load.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
09-24-2013, 11:27 AM | #5 | |
Cluster King
09-24-2013, 11:28 AM | #6 |
Proprietor of Dale's Corner
Sounds like a u joint to me..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-24-2013, 11:40 AM | #7 |
Active Member
Depending on the "chirp" I had a brake shoe that was too close to the drum making a scratching type of noise.
09-24-2013, 11:53 AM | #8 |
Not 100% sure that it's coming from the rear, but it sounds like it. According to my doctor, I've got the hearing of a 60 y.o. (I'm 37, ), plus dual turbo mufflers. I hope it's not the front brakes, since I just put new pads on less than a year and ~12K miles ago. Anyway, I'll check both and try jacking it up and spinning the wheels to see if I can more precisely locate the source of the sound.
09-24-2013, 01:50 PM | #9 |
U-joint
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
09-24-2013, 05:26 PM | #10 | |
Definitely the U-joint. The chirp changes because of the load on the joint. Some do it during acceleration and not when coasting, others are opposite. At this point the needles are rusty and dry, soon they will crumble and you will have a clunk when going into reverse.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-26-2013, 04:38 PM | #11 |
I just wanted to update and add some information.
The sound quit 2 days ago and hasn't come back. Fixed... Also, the u-joints are about 2 y.o. and have only 22K miles on them. I will crawl under this weekend and wiggle stuff around, but is it reasonable for them to go that soon.
09-26-2013, 04:43 PM | #12 |
I"m sure they haven't healed..it just might be the calm before the storm..It depends on how tight they were and lubrication. I've seen one cup that was tighter than the others and not take grease and wear out quickly..
09-26-2013, 04:58 PM | #13 |
When I was working in dealership, a customer brought in a pickup complaining of a growling coming from under the hood. I opened the hood and found a very unhappy racoon
"Negative people always seem to have a problem for every solution" |
09-26-2013, 05:03 PM | #14 |
Uh oh I can fix it..
09-26-2013, 06:44 PM | #15 |
Cluster King
Just a FYI, a u joint that is tight will make more noise if it is dry. Usually a u joint that is wore and has play will clunk but not chirp with rotation. The chirp comes from dry needles. The only way to really check it is to pull the shaft(s) out and see if the have restrictive movement. I would bet that if the chirp has stopped, the clunk will soon follow.
09-27-2013, 09:18 AM | #16 |
Ha! Maybe the birds nest finally fell off my drive shaft.
09-27-2013, 09:27 AM | #17 | |
